Hi in there !
I'm currently working on a project involving multiple communication protocol (as far as i figured out the way to achieve my goal).
- About the project :*
There are 3 machines. 1 Computer, 1 Teensy 3.2 I2C Master and 1 I2C Teensy 4 Slave with 3 encoders and 1 SPI Oled Screen (Adafruit 1331).
On the slave there are 3 encoders that sends the Master through i2C their values when changed (using EncoderTool library) as well as updating the Screen (with SPI). The master finally sends those received values to the computer with Serial communication to update a parameter.
Everything is fine so far. But, the idea is now to get the feedback from the computer when the parameter is moved in the software to update the encoder position (and therefore the screen). The datas then flow back from the computer to the slave following the same protocol pattern.
The application is for controlling a music software parameter which supposes the ability to feedback and update with the minimum latency and minimum drops.
The code seems to be working fine but the Screen update slows down a lot the data analysis so I cannot use it as the latency when moving the encoder increases. Whenever I remove this screen update, everything flows like a charm.
Is it linked to interferences in between SPI and the large amount of I2C incoming datas ?
I know OLED screens use a lot of ressources to run but is there a way to prioritize i2C data treatment compared to SPI update ?
I wonder if it's a matter of code being slow (due to bad coding) compared to what is capable the teensy 4 board or if the communication strategy is bad (communicating with i2C (which is not an option for me) and updating with SPI).
Hope it's clear ! Thanks in advance !
