Hello,
I am working on an art project and I want to combine a stepper (with limit switch) , led strip & audio file.
The stepper starts an moves toward a limit switch, after touching it will start a loop from 5 to 1000. Some // are in Dutch sorry!
/* Motor Homing code using AccelStepper and the Serial Monitor
Created by Yvan / https://Brainy-Bits.com
This code is in the public domain...
You can: copy it, use it, modify it, share it or just plain ignore it!
Thx!
#include "AccelStepper.h"
// Library created by Mike McCauley at http://www.airspayce.com/mikem/arduino/AccelStepper/
#define motorPin1 8 // IN1 pin op de ULN2003A driver
#define motorPin2 9 // IN2 pin op de ULN2003A driver
#define motorPin3 10 // IN3 pin op de ULN2003A driver
#define motorPin4 11 // IN4 pin op de ULN2003A driver
int stepsPerRevolution = 64; // stappen per omwenteling
float degreePerRevolution = 5.625; // graden per omwenteling
// AccelStepper Setup
AccelStepper stepperX(AccelStepper::HALF4WIRE, motorPin1, motorPin3, motorPin2, motorPin4);
// Define the Pins used
#define home_switch 12 // Pin 9 connected to Home Switch (MicroSwitch)
// Stepper Travel Variables
int move_finished=1; // Used to check if move is completed
long initial_homing=-1; // Used to Home Stepper at startup
Serial.begin(9600); // Start the Serial monitor with speed of 9600 Bauds
pinMode(home_switch, INPUT_PULLUP);
delay(5); // Wait for EasyDriver wake up
// Set Max Speed and Acceleration of each Steppers at startup for homing
stepperX.setMaxSpeed(2000.0); // Set Max Speed of Stepper (Slower to get better accuracy)
stepperX.setAcceleration(1000.0); // Set Acceleration of Stepper
stepperX.setSpeed(2000); // stel de huidige snelheid in
// Start Homing procedure of Stepper Motor at startup
Serial.print("Stepper is Homing . . . . . . . . . . . ");
while (digitalRead(home_switch)) { // Make the Stepper move CCW until the switch is activated
stepperX.moveTo(initial_homing); // Set the position to move to
initial_homing--; // Decrease by 1 for next move if needed
stepperX.run(); // Start moving the stepper
delay(5);
stepperX.setCurrentPosition(0); // Set the current position as zero for now
stepperX.setMaxSpeed(1000.0); // Set Max Speed of Stepper (Slower to get better accuracy)
stepperX.setAcceleration(500.0); // Set Acceleration of Stepper
initial_homing=1;
while (!digitalRead(home_switch)) { // Make the Stepper move CW until the switch is deactivated
stepperX.run();
initial_homing++;
delay(5);
Serial.println("Homing Completed TOT HIER");
Serial.println("");
stepperX.setMaxSpeed(1000.0); // Set Max Speed of Stepper (Faster for regular movements)
// Graden van bewegingen dus eerst naar 30 graden, dan naar -30 graden dan naar 60 graden etc.
int steps[] = { 1000, 5, 1000, 5, 1000, 5, 1000, 5, };
// Het totaal aantal bewegingen in steps[]
int stepsCount = 5;
// Houdt bij welke positie van steps[] we gaan uitvoeren
int stepsIndex = 0;
// Als de stepper niet beweegt en geen afstand meer hoeft af te leggen
if (!stepperX.isRunning() && stepperX.distanceToGo() == 0) {
// Beweeg de stepper naar het aantal graden op de positie stepIndex van steps[]
stepperX.moveTo(degToSteps(steps[stepsIndex]));
// Verhoog de index als de beweging klaar is
stepsIndex++;
// Als we alle posities in steps[] gehad hebben
if (stepsIndex > stepsCount) {
// Begin overnieuw bij 0
stepsIndex = 0;
stepperX.run();
* Rekent het aantal graden om naar het aantal stappen
* In ons voorbeeld van 45 graden: 64 / 5,625 = 1024 stappen
float degToSteps(float deg) {
return (stepsPerRevolution / degreePerRevolution) * deg;
I want to combine the movement of the stepper with the fade in (50 to 250) and fade out (250 to 50) of a led strip. The led strip should be on 50 when the stepper is on 5 and on 250 when the stepper is on 1000. And I also want to start an audio file at the beginning of every loop! I know that I could remove te delay to combine the scripts and replace them with Milles but don’t know how to do this. And I also don’t know how to include the audio! Please help
#include "FastLED.h"
#define NUM_LEDS 208
CRGB leds[NUM_LEDS];
#define PIN 6
FastLED.addLeds<WS2811, PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
FadeInOut(0xff, 0xff, 0xff);
void FadeInOut(byte red, byte green, byte blue){
float r, g, b;
for(int k = 50; k < 250; k=k+1) {
r = (k/256.0)*red;
g = (k/256.0)*green;
b = (k/256.0)*blue;
setAll(r,g,b);
showStrip();
delay(60);
for(int k = 250; k >= 50; k=k-2) {
r = (k/256.0)*red;
b = (k/256.0)*blue;
setAll(r,g,b);
showStrip();
delay(60);
void showStrip() {
#ifndef ADAFRUIT_NEOPIXEL_H
// FastLED
FastLED.show();
#endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
// FastLED
leds[Pixel].r = red;
leds[Pixel].g = green;
leds[Pixel].b = blue;
#endif
void setAll(byte red, byte green, byte blue) {
for(int i = 0; i < NUM_LEDS; i++ ) {
setPixel(i, red, green, blue);
showStrip();
Thank you for reading this!
