Combining two codes
hello,
I am trying to use the x,y,z from an accelerometer in a function type code to hopefully give me some roll and pitch angles that I can use to correct a hexapod robot. although I cannot get them to work. I am new to programming so its probably fairly simple:
there's this code from the adafruit LIS3DH:
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
// Used for software SPI
#define LIS3DH_CLK 52
#define LIS3DH_MISO 50
#define LIS3DH_MOSI 51
// Used for hardware & software SPI
#define LIS3DH_CS 53
// software SPI
Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
// hardware SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS);
// I2C
//Adafruit_LIS3DH lis = Adafruit_LIS3DH();
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
#define Serial SerialUSB
#endif
void setup(void) {
#ifndef ESP8266
while (!Serial); // will pause Zero, Leonardo, etc until serial console opens
#endif
Serial.println("LIS3DH test!");
// if (! lis.begin(0x18)) { // change this to 0x19 for alternative i2c address
// Serial.println("Couldnt start");
// while (1);
// Serial.println("LIS3DH found!");
lis.setRange(LIS3DH_RANGE_4_G); // 2, 4, 8 or 16 G!
Serial.print("Range = "); Serial.print(4 << lis.getRange());
Serial.println("G");
lis.read(); // get X Y and Z data at once
// Then print out the raw data
Serial.print("X: "); Serial.print(lis.x);
Serial.print(" \tY: "); Serial.print(lis.y);
Serial.print(" \tZ: "); Serial.print(lis.z);
/* Or....get a new sensor event, normalized */
sensors_event_t event;
lis.getEvent(&event);
/* Display the results (acceleration is measured in m/s^2) */
// Serial.print("\t\tX: "); Serial.print(event.acceleration.x);
// Serial.print(" \tY: "); Serial.print(event.acceleration.y);
// Serial.print(" \tZ: "); Serial.print(event.acceleration.z);
// Serial.println(" m/s^2 ");
delay(200);
and I would like the x,y,z to go into this:
int x, y, z; //three axis acceleration data
double roll = 0.00, pitch = 0.00; //Roll & Pitch are the angles which rotate by the axis X and y
void RP_calculate(){
double x_Buff = float(x);
double y_Buff = float(y);
double z_Buff = float(z);
roll = atan2(y_Buff , z_Buff) * 57.3;
pitch = atan2((- x_Buff) , sqrt(y_Buff * y_Buff + z_Buff * z_Buff)) * 57.3;
Also, as an extra how could I define these angles to be something I could add onto a 'servo.write(90+the'X value here')?
any help would be appreciated! thank you
harry
The same way you converted from radians to degrees - by scaling.
I've deleted your other cross-post @harrywarbs.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
