Combining two PWM signals together
Hi all,
I have two independant PWM signals that I would like to combine to get a an output as illustrated below:
I have generated both the PWM signals successfully, just need some guidance on the circuit required to combine them?
Thanks in advance :slight_smile:
Google "resistor adder".
If you use a 10k lin pot, then you can vary the mixing ratio.
Outside pins of the pot to the two PWM outputs, wiper is output.
Leo..
Amazing, thanks for your help @Wawa
