Combining two sketch together .....
Hello… My project has two parts:
Part 1: A pin gets high or low depending on certain conditions
Part 2: LCD display and DS18B20 as a digital thermometer
I have successfully run theses two codes separately; but how to combine them together so that i can ran them together in my Arduino Mega 2560
The codes are attached below:
Sketch for Part 1:
// These constants won't change:
const int analogPin = A0; // pin that the sensor is attached to
const int transistorPin = 40; // pin that the LED is attached to
const int dtmfPin1 = A1;// pin that the Q4 of MT8870 is attached to
const int dtmfPin2 = A2;
const int dtmfPin3 = A3;
const int dtmfPin4 = A4;
int value1 = 0;
int value2 = 0;
int value3 = 0;
int value4 = 0;
// initialize the LED pin as an output:
pinMode(transistorPin, OUTPUT);
//initialize the DTMF output pin as input
pinMode(dtmfPin1, INPUT);
pinMode(dtmfPin2, INPUT);
pinMode(dtmfPin3, INPUT);
pinMode(dtmfPin4, INPUT);
// initialize serial communications:
// read the value of the potentiometer:
int analogValue = analogRead(analogPin);
value1 = digitalRead(dtmfPin1);
value2 = digitalRead(dtmfPin2);
value3 = digitalRead(dtmfPin3);
value4 = digitalRead(dtmfPin4);
if (value1==HIGH&&value2==HIGH&&value3==HIGH&&value4==LOW)// 7
// if the analog value is high enough, turn on the LED:
if (analogValue < 150 ) {
digitalWrite(transistorPin, HIGH);
else if (analogValue > 450 ){
digitalWrite(transistorPin,LOW);
else {
if (value1==LOW&&value2==LOW&&value3==LOW&&value4==HIGH)//8
else if (value1==HIGH&&value2==LOW&&value3==LOW&&value4==HIGH)//9
// print the analog value:
Serial.println(analogValue, DEC);
Code for part 2:
// LCD Thermostat
// www.hacktronics.com
#include <OneWire.h>
#include <LiquidCrystal.h>
// Connections:
// rs (LCD pin 4) to Arduino pin 12
// rw (LCD pin 5) to Arduino pin 11
// enable (LCD pin 6) to Arduino pin 10
// LCD pin 15 to Arduino pin 13
// LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 13;    // pin 13 will control the backlight
OneWire  ds(8);        // ds18b20 pin #2 (middle pin) to Arduino pin 8
byte i;
byte present = 0;
byte data[12];
byte addr[8];
int HighByte, LowByte, SignBit, Whole, Fract, TReading, Tc_100, FWhole;
void setup(void) {
  pinMode(backLight, OUTPUT);
  digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
  lcd.begin(2,16);              // rows, columns.  use 2,16 for a 2x16 LCD, etc.
  lcd.clear();                  // start with a blank screen
  lcd.setCursor(0,0);           // set cursor to column 0, row 0
    if ( !ds.search(addr)) {
      lcd.clear(); lcd.print("No more addrs");
      ds.reset_search();
      return;
  if ( OneWire::crc8( addr, 7) != addr[7]) {
      lcd.clear(); lcd.print("CRC not valid!");
      return;
void getTemp() {
  int foo, bar;
  ds.reset();
  ds.select(addr);
  ds.write(0x44,1);
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);
  for ( i = 0; i < 9; i++) {
    data[i] = ds.read();
  LowByte = data[0];
  HighByte = data[1];
  TReading = (HighByte << 8) + LowByte;
  SignBit = TReading & 0x8000;  // test most sig bit
  if (SignBit) {
    TReading = -TReading;
  Tc_100 = (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
  Whole = Tc_100 / 100;          // separate off the whole and fractional portions
  Fract = Tc_100 % 100;
  if (Fract > 49) {
    if (SignBit) {
      --Whole;
      ++Whole;
  if (SignBit) {
    bar = -1;
    bar = 1;
  foo = ((Whole * bar) * 18);      // celsius to fahrenheit conversion section
  FWhole = (((Whole * bar) * 18) / 10) + 32;
  if ((foo % 10) > 4) {            // round up if needed
       ++FWhole;
void printTemp(void) {
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Temp is: ");
  lcd.setCursor(0,1);
  if (SignBit) {
     lcd.print("-");
  lcd.print(Whole);
  lcd.print(" C / ");
  lcd.print(FWhole);
  lcd.print(" F");
void loop(void) {
  getTemp();
  printTemp();
The onewire libraray and LCDdisplay library has been included in the actual code.
void loop(void) { getTemp(); printTemp(); delay(1000); }
Could you please tell me how to avoid using delay in the above portion of sketch 2?
The delay function is there in a few place of sketch 2...if i merge the two sketches; i cant have the delay fuction..how can i avoid using that?
Let us all intone the mantra..Read and understand the Blink Without Delay example, without delay. Ooooommm.
