Comercial Voltage regulator
Can you guys help me.
I'm trying to find a voltage regulator, that give me a 2.6V output. I need suggestions of one I can find easily.
thanks for the help
http://www.digikey.com/product-search/en?keywords=2.6v%20voltage%20regulator
Looks like about 2000 products.
You need to tighten your requirements a bit - is this for 50ma or 10A or ? (maybe spot welding?) What input do you intend to drive the regulator with? What kind of efficiency do you need? These will determine if you need a simple zener and resistor, a simple IC regulator or a switching regulator.
[u]"20 Questions"[/u] 1- Load Current ? 2- Regulation tolerance 3- Load ? (what is it powering) 4- What is the input voltage ? 5- Does it need to be an LDO ?
From the OPs other posts he may need it as an AtoD Vref.
Tom.... :)
