Command wont leave loop
So i am trying to create a rgb led code set that can be used with the lightblue app from ios
my code is able to get the correct commands i send in however when i send in the command for random colors it gets stuck in the loop when i send in another command.
for example if i send in r it makes the light red, b = blue and so on. those work fine but when i send in a = all color it gets stuck looping through the colors even after i send in another command.
#include <SoftwareSerial.h>
/*int led = 2; */
int redPin = 3; //whichever pin is connected to the red node of the rgb LED
int greenPin = 5; //whichever pin is connected to the green node of the rgb LED
int bluePin = 6; //whichever pin is connected to the blue node of the rgb LED
SoftwareSerial Bluetooth(0, 1);
int x;
  Bluetooth.begin(9600);
  pinMode(redPin, OUTPUT);
  char command;
  int randomC = 0;
  if (Bluetooth.available()) {
    command = Bluetooth.read();
    Serial.println("Input received:");
    if (command != 'a') {
      x = 0;
      getCommand(command);
      Serial.println("Not A: " + x);
    if (command == 'a') {
      x = 1;
      randomColors();
      Serial.println(" A: " + x);
    else {
      x = 0;
void getCommand(char command) {
  pinMode(4, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  switch (command) {
    case 'r': //RED
      digitalWrite(4, HIGH);
      setColor(255, 0, 0);
    case 'g': //GREEN
      setColor(0, 255, 0);
    case 'b': //BLUE
      setColor(0, 0, 255);
    case 'y':
      setColor(255, 255, 51);
    case 'o':
      setColor(255, 165, 0);
    case 'v':
      setColor(238, 130, 238);
    case 'm':
      setColor(255, 0, 255);
    case 'c':
      setColor(0, 255, 255);
    case 'e':
      setColor(128, 128, 128);
    case 'x': //TURNS OFF LIGHT
      digitalWrite(4, LOW);
      pinMode(redPin, LOW);
      pinMode(greenPin, LOW);
      pinMode(bluePin, LOW);
void randomColors() {
  do {
    int r1 = random(255);
    int r2 = random(255);
    int r3 = random(255);
    setColor(r1, r2, r3);
  while (x == 1);
void setColor(int red, int green, int blue) {
  analogWrite(redPin, red);
  analogWrite(greenPin, green);
  analogWrite(bluePin, blue);
Read your randomcolors() function over and over to yourself until you see the problem.
Paul
Paul_KD7HB:
Paul
problem problems...
aarg:
problem problems...
Sure! But one at a time.
Paul
so in the below code shouldnt the command change set the x value? if not 'a' it should set it to 0 if a set it to 1
and then in the loop i wrote shouldnt that continue until x is set to 0?
      x = 0;
      x = 1;
      randomColors();
  do {  //continue  while x=1
  while (x == 1);
darenr:
Yes, except that the code that sets it to zero is outside the loop and will never be executed.
Try:
  while (Bluetooth.available() == 0);
in place of:
  while (x == 1);
That will end your random color loop when a new character arrives from Bluetooth.
thank you, it worked perfectly
