Does the standard LiquidCrystal library support commandWrite() or must I use LCD4bit library?
I believe that you want to use such a command to send an arbitrary command to the LCD controller and I don't believe that the LiquidCrystal library has such a function. There's no reason that you can't write one of your own.
The best thing that you can do with the LCD4bit library is to completely forget about it. If you want to know why then just get a copy of the source code and read the comments.
Don
I looked at the LiquidCrystal library header file and there is a command function. For some reason it is not listed with all the other functions on the Arduino library page. An example of use would be command(0x04) rather than commandWrite(0x04).
