hello
voici le code donné par le fabricant et la doc du driver
int PUL=7; //define Pulse pin
int DIR=6; //define Direction pin
int ENA=5; //define Enable Pin
pinMode (PUL, OUTPUT);
pinMode (DIR, OUTPUT);
pinMode (ENA, OUTPUT);
for (int i=0; i<6400; i++) //Forward 5000 steps
digitalWrite(DIR,LOW);
digitalWrite(ENA,HIGH);
digitalWrite(PUL,HIGH);
delayMicroseconds(50);
digitalWrite(PUL,LOW);
for (int i=0; i<6400; i++) //Backward 5000 steps
digitalWrite(DIR,HIGH);
When “EN” is Low, the motor is in a free states (Off-line mode). In this mode, you can adjust the motor shaft position manually; when “EN” is High (Vacant), the motor will be in an automatic control mode.
"Direction" is the motor direction signal pin,
"PULSE" is the motor pulse signal pin. Once the driver get a pulse, the motor move a step.
