When i just connect the 9v input then my led on the arduino start to shine weak but everything work fine if i connect both the arduino and the 9v input. So i am not sure if my common ground is connected correctly. So maybe some of you could check my circuit.
The first to do is to connect the grounds together for all power supplies. Then they have a base for the Exchange of signals between the different modules. Make this connection in one "central"place.
