Common PCF8574 i2c LCD module as Button interface.
Here is simple code to utilize common/cheap ebay i2c lcd adapter for buttons instead.
To wire it put your buttons between GND Pin #1 (nearest i2c connections with square around it) and:
Pin #4 (button 1)
Pin #5 (button 2)
Pin #6 (button 3)
Pin #11 (button 4)
The following pins are also suitable/available:
Pin #12
Pin #13
Pin #14
note: can also change i2c address using solder jumpers A0, A1 & A2
#include<Wire.h>
byte x=0;
    Wire.begin();
    Wire.requestFrom(0x27,1); // http://playground.arduino.cc/Main/I2cScanner <-- if you need to find your devices address
    if(Wire.available())     //If the request is available
        x=Wire.read();       //Receive the data
     if (x==246) Serial.println(1);
     else if (x==245) Serial.println(2);
     else if (x==243) Serial.println(3);
     else if (x==231) Serial.println(4);
       // else if (x==247) Serial.println(0);//uncomment if needed
    //Serial.println(x);uncomment to see raw data
    delay(100);
