Common SMD diode recommendation?
I'm looking for an SMD diode to use with reset pin in my ATMega328p based board. Previously in thru the hole version of the board I used 1N4148 diode, just because it was cheap and easy to find. What would be a good cheap SMD equivalent?
How about a 1N4148?
Choices
This one?
Grumpy_Mike: How about a 1N4148?
Choices
This one?
Hehe ok, thanks 1N4148 it is then! :) So SOD-123 is common package for SMD diodes?
Schottky diodes are worth considering, so an SS12 / 13 / 14 or similar, 1A continuous
so handy for power as well as logic, so handy to have.
I like SOD80 but, they do role.
LarryD: I like SOD80 but, they do role.
Yikes! No way!!! :)
I used them here http://www.thebox.myzen.co.uk/Hardware/Econo_Monome.html Mainly because I had them. See the photos.
Grumpy_Mike: I used them here http://www.thebox.myzen.co.uk/Hardware/Econo_Monome.html Mainly because I had them. See the photos.
That's one impressive project!!! I can only imagine how long it took you to cut all that lattice!
