Communicating Arduino Shield W5100 Socket Client with PC as a Socket Server
Hello,
I'm trying to communicate an Arduino with a Shield W5100 the cable is on a switch then the PC, both cables are T-568A standard.
I need to sendo character "A" from arduino and receive receive "A" to confirm that read, then after do a local operation pc will give another signal "%1" that finalized the operation then the arduino will send pin out1 0 to 1 and then will receive pin in2 0 to 1 to close the communication and restart all again.
My problem is with the socket comunication between PC(Server) and Arduino(Client).
I already test the all examples in the internet, but there is no communication for example:
PC 192.168.0.2 port 1985 as a Server
Arduino 192.168.0.1 port 1985 as a Client
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 0, 1 }; //Arduino with W5100
byte server[] = { 192, 168, 0, 2 }; // PC
EthernetClient client;
Ethernet.begin(mac, ip);
Serial.println("connecting...");
if (client.connect(server, 1985)) {
Serial.println("connected");
client.println("GET /search?q=arduino HTTP/1.0");
client.println();
Serial.println("connection failed");
if (client.available()) {
char c = client.read();
Serial.print(c);
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
for(;:wink:
Please, if somebody can help me i will be thankfull, if do you need more information, feel free to do it.
Thanks in advanced,
Francis
Is your PC running a web server?
it is unclear from your post if the shield connects to network and the examples work?
the port could be blocked on PC firewall
