Communicating Arduino with a Computer Wirelessly
Hello guys, I have a project that uses Arduino mega and process the data, I want to send the data to a PC and perform some processing on it and send back a reply to the Arduino, I have no idea what can I use for this ? any suggestions ? I want something easy and Cheap, the distance isn't a big issue, any wireless will do for me! I dont' have much experience with interfacing so I'd really like an easy option :slight_smile: thanks so much
Look into bluetooth modules, can find units that are advertised as a "serial cable replacement".
Thanks, ill look into this, i'd rather use a wifi shield or a Xbee tho :cold_sweat:
XBees are easy. They are reliable. They deal with all the retransmission issues if data is lost/garbled. What they are not is cheap. But, you get what you pay for.
ok Thank you :slight_smile:
So what do i need for this ?? the Xbee shield, TX RX both the same and XBee interface with the PC right ?
the Xbee shield
An XBee shield. There are several to choose from - none are ideal. Some are less pathetic than others. I like the Sparkfun model myself.
TX RX both the same
If you mean can an XBee transmit and receive, the answer is yes.
Depends on what you mean by "interface with". I have yet to see a PC with an XBee socket. So, you need something to connect the XBee to the PC. Typically, that is a USB Explorer. That makes the device appear as a serial port. The PC can't tell the difference between an XBee on a USB Explorer and an Arduino on a USB cable. Both are just serial devices on a virtual COM port.
Oh, yes I meant about the USB-XBEE Adaptor (Connect Zigbee to PC). I think that what you mean :smiley: and me too. I have to program it using the Arduino tho ? or is it ready-programmed ? and also with the Xbee board?
