I am working on a project that requires communication between 4 microcontrollers.
What I am currently using is a mega with each serial port attached to another microcontroller.
Now I think it is obvious that such alternative
a) uses a lot of wiring
b) adds significant overhead to the CPU
So I was thinking perhaps going a bit simpler and add I2C slave capability to each of the micros and query them individually would be much simpler. I already have the libraries all set up for EEPROM access so it's as easy as writing a line of code on the slave.
Piton:
I'm not that expert, but i dont think eprom is what you are looking for.
I think you should follow wire.h examples. They are quite straight forward.
Sorry for the confusion. Im using a wire function to read a particular address. In this case its used for an I2C memory, but could read anything else, by specifying the I2C address and the memory address.
