Hi! My name is Renato and I am an apprentice with regards to the Arduino. I have this project that I am doing for school which requires me to have a website that can send commands to the arduino board to have its motor spin. I m having a problem figuring out how I can have a function or something on this website code to call into the arduino code to make the motor move. How do I communicate from the website in the SD. card and the Arduino code outside of it? I just want to have a function that moves the motor when the alarm on the website sounds. As in this snippet of the website:
if (typeof this.hourwake!="undefined"){ //if alarm is set
if (this.ctref.title==(this.hourwake+":"+this.minutewake+":"+this.secondwake)){
clearInterval(jsalarm.timer)
countdowntimer()
Heres the code. The website that is on the SD card can be accessed through this website:www.itcup.skuttcatholic.com. So you can just inspect the source on this website to see the code of it.
Here is the code on the arduino. It simply reads the SD Card:
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0x01, 0xE8 };
IPAddress ip(192,168,0,38);// IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
File webFile;
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for debugging
pinMode(9,OUTPUT);
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
