Hi all,
for starters, I have a strong programming background but am trying to learn a bit more about circuitry/microcontrollers, so this is my first experience with Arduino (I know very little so far).
I have a project where I want to basically have a laptop connected to an arduino board, and be able to communicate between the two. For example, I want the laptop to be able to send commands to the arduino board to do things like drive a servo. I'd also like to be able to get data back from the arduino board - for example, if I have a temperature sensor, I'd like the computer to be able to read it. Thus this isn't an entirely standalone arduino project.
My main questions -
Does anyone have any useful links or information on how this can be accomplished? Any similar projects people have blogged/written about, etc
How can I communicate between the two? Can I use the usb port, and is there a driver on the computer side that works on Windows that I can use to call into the arduino board, etc?
I'm fine with reading so would greatly appreciate any useful links. Thanks!
This is my code for sending the time in a packed value to the arduino.
It also waits for the arduino to ask for the time. This is a very simple example and you don't have to use python.
import serial, sys, os, time, struct, datetime
SERIALPORT = "COM2" # Change this to your serial port!
day = 0
def packIntegerAsULong(value):
return struct.pack('I', value)
try:
ser = serial.Serial(SERIALPORT, 9600)
except serial.SerialException:
print "no device connected - exiting"
sys.exit()
while 1 == 1:
now = datetime.datetime.now()
day2 = now.day
dst_adj_time=time.time()-time.altzone
if time.localtime().tm_isdst==0:
dst_adj_time=dst_adj_time-3600
if day2!=day:
ser.write('6')
ser.write(packIntegerAsULong(int(dst_adj_time)))
print time.ctime()
day = now.day
if ser.inWaiting():
outinit = eval(ser.readline())
if outinit==1001:
ser.write('6')
print time.ctime()
You can check : Processing. http://www.processing.org. It can do both ways. Just program it. I did a few experiments with Processing and Arduino. Just basic - "hello word"
There is agood youtube tutorial series for the arduino made by jeremy blum...in part 6 it talks about serial processing...you can have a look, maybe it will help
