Hello, I conected Arduino Mega with NodeMCU 8266 ESP12 with serial connection. When ESP accepted message from Arduino Mega, submite at first of all accepted message from MQTT server (2 messages: alarm/stav and alarm/zaciatok) next from Arduino Mega and next message from MQTT server (1 message: alarm/koniec). I want to run like this:
Accepted (submite) all message from arduino to ESP12E and next to send to MQTT server. And reverse: accepted (submite) message from MQTT server to NODEMCU 8266 ESP12 and next send to Arduino Mega.
I send you a code and Serial print to monitor. Exchange messages does not correctly. WHY? Thanks
#include <ArduinoJson.h>
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h> // ESP8266
#include <MQTTClient.h>
#include <Servo.h>
Servo myservo;
SoftwareSerial linkSerial(D6,D5); //komunikácia po seriovej linke
//------ wifi settings
char ssid[] = "T-Optik"; // Change this to your network SSID (name).
char pass[] = "zahrada123"; // Change this your network password
//------ MQTT broker settings and topics
const char* broker = "brka123.cloud.shiftr.io";
char clientID[] ="Inteligentný dom";
char mqttUserName[] = "brka123";
char mqttPass[] = "12345678";
WiFiClient net;
MQTTClient client;
unsigned long lastMillis = 0;
String tempAlarmStav;
String tempAlarmZaciatok;
String tempAlarmKoniec;
String tempRed1;
String tempGreen1;
String tempBlue1;
int tempServoDvere;
//========================================= connect
void connect() {
Serial.print("\nconnecting to wifi.");
Serial.print(".");
//--- create a random client id
Serial.print("\nconect to server...");
while (!client.connect(clientID,mqttUserName,mqttPass)) {
Serial.print(".");
Serial.println("\nconected!");
client.subscribe("alarm/stav",2);
client.subscribe("alarm/zaciatok",2);
client.subscribe("alarm/koniec",2);
client.subscribe("servo/dvere");
client.subscribe("servo/okno");
client.subscribe("svetlo/izba_1/red1");
client.subscribe("svetlo/izba_1/green1");
client.subscribe("svetlo/izba_1/blue1");
client.subscribe("svetlo/izba_2");
client.subscribe("svetlo/izba_3");
//========================================= messageReceived
void messageReceived(String &topic, String &payload) {
StaticJsonDocument<800> doc;
//DynamicJsonDocument doc(1024);
Serial.println("Message from MQTT server");
Serial.println("incoming: " + topic + " - " + payload);
Serial.println("-------------------------");
//tempAlarmZaciatok="999";
//tempAlarmKoniec="999";
//tempAlarmStav="999";
//tempServoDvere="999";
if (topic=="alarm/stav")
tempAlarmStav=payload;
if (topic=="alarm/zaciatok")
tempAlarmZaciatok=payload;
if (topic=="alarm/koniec")
tempAlarmKoniec=payload;
if (topic=="servo/dvere")
tempServoDvere=payload.toInt();
myservo.write(tempServoDvere);
if (topic=="svetlo/izba_1/red1")
tempRed1=payload;
if (topic=="svetlo/izba_1/green1")
tempGreen1=payload;
if (topic=="svetlo/izba_1/blue1")
tempBlue1=payload;
//vysielanie Json dokumentu po seriovej linke
// Send the JSON document over the "link" serial port
//if ((tempAlarmZaciatok!="999")||(tempAlarmKoniec!="999")||(tempAlarmStav!="999")||(tempServoDvere!="999"))
doc["stav"] = tempAlarmStav;
doc["zaciatok"] = tempAlarmZaciatok;
doc["koniec"] = tempAlarmKoniec;
doc["izba1Red1"] = tempRed1;
doc["izba1Green1"] = tempGreen1;
doc["izba1Blue1"] = tempBlue1;
serializeJson(doc, linkSerial);
void prijatSpravuArduinoMega()
//príjem z ArduinoMega a odvysielanie na MQTT server
if (linkSerial.available())
// Allocate the JSON document
//DynamicJsonDocument doctoesp(1024);
// Read the JSON document from the "link" serial port
DeserializationError err = deserializeJson(doc, linkSerial);
Serial.setTimeout(2000);
if (err == DeserializationError::Ok)
client.publish("alarm/stav",doc["stav"].as(),true,2);
client.publish("alarm/zaciatok",doc["zaciatok"].as(),true,2);
client.publish("alarm/koniec",doc["koniec"].as(),true,2);
Serial.println("Message from Arduino Mega:");
Serial.print("AlarmStav = ");
Serial.println(doc["stav"].as());
Serial.print("AlarmZaciatok = ");
Serial.println(doc["zaciatok"].as());
Serial.print("AlarmKoniec = ");
Serial.println(doc["koniec"].as());
Serial.println("---------------------------");
// Print error to the "debug" serial port
Serial.print("deserializeJson() returned ");
Serial.println(err.c_str());
// Flush all bytes in the "link" serial port buffer
while (linkSerial.available() > 0)
linkSerial.read();
//========================================= setup
myservo.attach(D4);
linkSerial.begin(4800);; //iniciácia po seriovej linke na arduino
WiFi.begin(ssid, pass); // Note: Local domain names (e.g. "Computer.local" on OSX) are not supported by Arduino. You need to set the IP address directly.
client.begin(broker, net);
client.onMessage(messageReceived);
connect();
//========================================= loop
client.loop();
delay(10); // <- fixes some issues with WiFi stability
if (!client.connected())connect();
prijatSpravuArduinoMega();
pokus_esp.ino (5.12 KB)
