Communication Arduino UNO with Xbee modem
Hello All,
This is my first time programming Xbee modem. I face up some difficulties conserning the programming of the Xbee modem using the program XCTU. Regarding the device which I have are the followings: - Arduino UNO - Xbee Pro Shield (www.funduino.com) - Xbee2 modem
Steps for programming are the followings: 1) connect only the arduino with my laptop and upload just two line of code void setup() { } void loop() { }
2) close the arduino programming environment, plug in the Xbee modem into the Xbee shield and both of them into aruino UNO
3) Reconnect to my laptop and run the XCTU. I have test all choice from the discover devices but I cannot found the Xbee modem.
Moreover appears a message said please press the "Reset button" but when I press it nothing change.
Could you please help me with this problem?
Thank you in advance.
What is XCTU ?
I don’t have any XBee devices but in other Threads in this Forum I believe they work with the code in Serial Input Basics
…R
Get one of these: https://www.sparkfun.com/products/11812. Problem solved.
