HELLO,
I am making a simle code to communicat 2 arduinos Uno . the first board send a binary msg and the second one recieve it
you find here my code that i used . the problem is that in the monitor of the reciever I don't have the same msg that the first board have sent!!
could you please tell me wat's wrong with the code?
//master sending a msg
byte msg= 0b10110110;
while (!Serial);
Serial.println(msg);
// receive msg
byte recieved_data = 0;
while(!Serial);
if (Serial.available() > 0){
recieved_data = Serial.read();
Serial.println(recieved_data,BIN);
@thalesmaissa, your topic has been moved to a more suitable location on the forum.
What does it print at the receiver side?
You are aware that the USB connection makes use of pins 0 and 1?
thank you .
no i don't know that so i have to change and use other pins using the librery softwareSerial??
here what i get in the serial:
anyone can help please??
I realy need to solve this problem to continue my work.
Use SoftwareSerial. And don't send data like a maniac (
) Just add a delay of e.g. 500 ms or 1 second.
Note that one of the beauties of the Arduino environment is that you can easily test things.
your code is working fine from what I can see! ![]()
since you are using 'println' what you are transmitting is the ASCII value for characters '1', '8', '2' + CRLF
With println, you are sending a TEXT string, not a byte with value 182. to do the latter, you would use Serial.write().
Hope that helps....
thank you for your request I understand.
I am going to try with serial write
