Communication between 2 H18(similar to H10) bluetooth module
Hi, I just started to use Arduino and in our project, we need to establish communication between 2 Bluetooth modules. We are using HM18 module. However, the mySerial.available() always returns 0 although the 2 Bluetooth could connect automatically (light stop blinking).
Code for sending
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10,11);
int trigPin = 6;
int echoPin = 7;
int ledp=8;
  Serial.begin(19200);
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
void loop() { // run over and over
  long duration, distance;
  digitalWrite(trigPin,HIGH);
  delayMicroseconds(1000);
  digitalWrite(trigPin, LOW);
  duration=pulseIn(echoPin, HIGH);
  distance =(duration/2)/29.1;
//  Serial.print(distance);
//  Serial.println("CM");
  delay(10);
  if((distance<=20))
    digitalWrite(ledp,HIGH);
    mySerial.write(111);
    //Serial.println("distance");
  else{
    digitalWrite(ledp,LOW);
code for receiving
int ledp=8;
int buz=9;
int timesRepeat=0;
  pinMode(ledp,OUTPUT);
  pinMode(buz,OUTPUT);
  mySerial.println("Hello, world?");
  if (mySerial.available()>0) {
    delay(1);
    int data = mySerial.read();//read()readStringUntil('\n')
    //Serial.println("mySerialavailable");
    //Serial.println(data);
    //if alert condition match
    if(timesRepeat!=0){
      timesRepeat--;
      delay(50);
    else{
      if(data==111){
          Serial.println("alert");
          //digitalWrite(ledp,HIGH);
          timesRepeat=20;
I've been working on this for hours but still no clue,,,
Thanks for the help in advance!
