Communication between Arduino and drum software: problem with hairless MIDI
Hello,
I tried making a drum Kit using Arduino UNO R3 board with DIP ATmega328P. Arduino seems to be working properly. I conveyed MIDI signal from Arduino to my PC (OS: windows 8) through the USB cable. I used virtual Hairless MIDI converter with LoopBe internal MIDI to make the connection between receiving MIDI signals and addictive drums software. However Hairless MIDI does not show any response. As I know, it should light up when it receives and sends data. Instead it says, "FTDI latency trick failed". Can anyone give any suggestion how to fix?
You have a fake FTDI chip and need to roll back the driver to use the older driver before they updated the driver to make fake chips not work.
