Hallo every one
I have some trouble communicating with my ICs 74hc595.
I have designed a sketch which I already rebuild, but I have no experience how should I control them.
Thanks
P.S. If this post is in a wrong topic, I'm sorry, I'm new here
Hallo every one
Thanks
Here I post my code that has been worked well with
3 lines of 7segment, each lines consist of 4 7segment
line 1: 7 7 7 7
line 2: 7 7 7 7
line 3: 7 7 7 7
it means, each line using 4 IC 74hc595.
Hope you may understand.
void setup();
void loop();
void increment (int line);
void show(int numberToDisplay,int fromLine);
void sendSerialData (byte registerCount,byte *pValueArray,int fromLine);
void sendSerialDatainitial(byte registerCount,byte *pValueArray,int fromLine);
int switchPin = A5;
int no1=1;
int no2=1;
int no3=1;
// Which pins are connected to which LED
const byte redLED0 = 2;
const byte redLED1 = 3;
const byte redLED2 = 4;
// Time periods of blinks in milliseconds (1000 to a second).
const unsigned long redLED0interval = 2000;
const unsigned long redLED1interval = 3000;
const unsigned long redLED2interval = 4000;
// Variable holding the timer value so far. One for each "Timer"
unsigned long redLED0timer;
unsigned long redLED1timer;
unsigned long redLED2timer;
// This pin gets sets low when I want the 595s to listen
const int pinCommLatch1 = 5;
const int pinCommLatch2 = 6;
const int pinCommLatch3 = 7;
// This pin is used to pass the next bit
const int pinData1 = 8;
const int pinData2 = 9;
const int pinData3 = 10;
// This pin is used by ShiftOut to toggle to say there's another bit to shift
const int pinClock1 = 11;
const int pinClock2 = 12;
const int pinClock3 = 13;
// Definitions of the 7-bit values for displaying digits
byte g_digits [10];
//Machine Config in integer array
int MachineConfig[3][3];
// Current number being displayed
int g_numberToDisplay = 0;
// Number of shift registers in use
const int g_registers = 4;
// Array of numbers to pass to shift registers
byte g_registerArray [g_registers];
pinMode (redLED0, OUTPUT);
pinMode (pinCommLatch1, OUTPUT);
pinMode (pinData1,OUTPUT);
pinMode (pinClock1,OUTPUT);
//config for line 1
MachineConfig[0][0]=5; //pinCommLatch line 1
MachineConfig[0][1]=8; //pinData line 1
MachineConfig[0][2]=11; //pinClock line 1
//config for line 2
MachineConfig[1][0]=6; //pinCommLatch line 2
MachineConfig[1][1]=9; //pinData line 2
MachineConfig[1][2]=12; //pinClock line 2
//config for line 3
MachineConfig[2][0]=7; //pinCommLatch line 3
MachineConfig[2][1]=10; //pinClock line 3
MachineConfig[2][2]=13; //pinData line 3
// Setup the digits array
g_digits [0] = 1 + 2 + 4 + 8 + 16 + 32 + 00;
g_digits [1] = 0 + 2 + 4 + 0 + 00 + 00 + 00;
g_digits [2] = 1 + 2 + 0 + 8 + 16 + 00 + 64;
g_digits [3] = 1 + 2 + 4 + 8 + 00 + 00 + 64;
g_digits [4] = 0 + 2 + 4 + 0 + 00 + 32 + 64;
g_digits [5] = 1 + 0 + 4 + 8 + 00 + 32 + 64;
g_digits [6] = 1 + 0 + 4 + 8 + 16 + 32 + 64;
g_digits [7] = 1 + 2 + 4 + 0 + 00 + 00 + 00;
g_digits [8] = 1 + 2 + 4 + 8 + 16 + 32 + 64;
g_digits [9] = 1 + 2 + 4 + 8 + 00 + 32 + 64;
//for loop 0-2 int
for(int i=0;i<3;i++){
sendSerialDatainitial(g_registers, g_registerArray,i);
byte registerCount, // How many shift registers?
byte *pValueArray,int fromLine) // Array of bytes with LSByte in array [0]
// g_registerArray [4] = g_digits [0];
g_registerArray [3] = g_digits [0];
g_registerArray [2] = g_digits [0];
g_registerArray [1] = g_digits [0];
g_registerArray [0] = g_digits [0];
int PINCommLatch=MachineConfig[fromLine][0];
int PINData=MachineConfig[fromLine][1];
int PINClock=MachineConfig[fromLine][2];
pinMode (PINCommLatch, OUTPUT);
pinMode (PINData, OUTPUT);
pinMode (PINClock, OUTPUT);
// Signal to the 595s to listen for data
digitalWrite (PINCommLatch, LOW);
for (byte reg = registerCount; reg > 0; reg--)
byte value = pValueArray [reg-1];
for (byte bitMask = 128; bitMask > 0; bitMask >>= 1)
digitalWrite (PINClock, LOW);
digitalWrite (PINData, value & bitMask ? HIGH : LOW);
digitalWrite (PINClock, HIGH);
// Signal to the 595s that I'm done sending
digitalWrite (PINCommLatch, HIGH);
} // sendSerialData
// Simple function to send serial data to one or more shift registers by iterating backwards through an array.
// Although g_registers exists, they may not all be being used, hence the input parameter.
byte *pValueArray, // Array of bytes with LSByte in array [0]
int fromLine)
byte value = pValueArray [reg - 1];
} // sendSerialData
if (digitalRead(switchPin))
blinks();
void blinks()
// Handling the blink of one LED.
if ( (millis () - redLED0timer) >= redLED0interval)
digitalWrite (redLED0, HIGH);
delay (1000);
digitalWrite (redLED0, LOW);
increment (0);
redLED0timer = millis ();
if ( (millis () - redLED1timer) >= redLED1interval)
digitalWrite (redLED1, HIGH);
digitalWrite (redLED1, LOW);
increment (1);
redLED1timer = millis ();
if ( (millis () - redLED2timer) >= redLED2interval)
digitalWrite (redLED2, HIGH);
digitalWrite (redLED2, LOW);
increment (2);
redLED2timer = millis ();
/* int line1 = random (1,3);
int line2 = random (1,4);
int line3 = random (1,6);
int k=0;
if(line1==1)
digitalWrite(2, HIGH); // set the LED on
delay(300);
digitalWrite(2, LOW);
increment(0);
if(line2==1)
digitalWrite(3, HIGH); // set the LED on
delay(300);
digitalWrite(3, LOW);
increment(1);
if(line3==1)
digitalWrite(4, HIGH); // set the LED on
delay (200);
digitalWrite(4, LOW);
increment(2);
void increment(int line)
if(line==0)
g_numberToDisplay = no1;
no1++;
show(g_numberToDisplay,line);
}else if(line==1)
g_numberToDisplay = no2;
no2++;
else if(line==2)
g_numberToDisplay = no3;
no3++;
if (numberToDisplay < 10)
g_registerArray [0] = g_digits [numberToDisplay];
else if (numberToDisplay < 100)
//g_registerArray [4] = g_digits [0];
g_registerArray [1] = g_digits [numberToDisplay / 10];
g_registerArray [0] = g_digits [numberToDisplay % 10];
else if (numberToDisplay < 1000)
g_registerArray [2] = g_digits [numberToDisplay / 100];
g_registerArray [1] = g_digits [(numberToDisplay % 100) / 10];
g_registerArray [3] = g_digits [numberToDisplay / 1000];
g_registerArray [2] = g_digits [(numberToDisplay % 1000) / 100];
// else
//g_registerArray [4] = g_digits [numberToDisplay / 10000];
//g_registerArray [3] = g_digits [(numberToDisplay % 10000) / 1000];
//g_registerArray [2] = g_digits [(numberToDisplay % 1000) / 100];
//g_registerArray [1] = g_digits [(numberToDisplay % 100) / 10];
//g_registerArray [0] = g_digits [numberToDisplay % 10];
sendSerialData (g_registers, g_registerArray, fromLine);
