Communication between arduino and processing not working!?
So this is part of a larger project but I can’t seem to get the basics working. The arduino sends a message (1 or 0) which adds or subtracts from the variable ‘num’. Num determines the position of a rect. Everything works fine, but for some reason it doesn’t subtract from num when the rect is in the middle third. It is hard to explain but if you run the code it will be a lot easier to understand.
Arduino code:
  pinMode(13,INPUT);  //Move left
  pinMode(10,INPUT);  //Move right
  if(digitalRead(13)==HIGH) //Send message to move left
    Serial.write(2);
    delay(200);
  if(digitalRead(10)==HIGH) //Sent message to move right
    Serial.write(1);
    delay(200);
Processing code:
import processing.serial.*;
Serial myPort;
int num = 1;
  size(500,500);
  myPort = new Serial(this, Serial.list()[4], 9600);
  rectMode(CENTER);
void draw() {
  background(0);
  if(num>=1&&num<=2&&myPort.read()==1)  //Add 1 if rect is in the first or second third
    num++;
  else if(num>=2&&num<=3&&myPort.read()==2)  ////Subtract 1 if rect is in the second or third third
    num--;
  rect(num*width/3-(width/6),height/2,width/3,height); //Display rect
You do this:
if(num>=1&&num<=2 ...
else if(num>=2&&num<=3 ...
which is the same thing as doing:
if (num == 1 || num == 2)
else if (num == 2 || num == 3)
Maybe that’s the problem?
No, but you are looking in the right place.
Serial port data arrives slowly. The draw() function is not called as fast as the loop() function in Arduino, but it is still called a lot.
Now, suppose that draw is called a dozen times between bytes arriving. On each pass, myPort.read() will not equal 1 (or 2). Now, further, suppose that a 2 arrives. myPort.read() will not return a 1, so the 2 is discarded.
And, the next character hasn’t arrived, yet, so this will not be true, either.
You should read a value from the port, and store it in a variable. Then, if the variable contains something other than -1, use the value that it does contiain:
int ardVal = myPort.read();
if(ardVal != -1)
   if(num >= 1 && num <= 2 && ardVal == 1)
   else if(num >= 2 && num <= 3 && ardVal == 2)
Notice, too, the spaces added tomakeyourcodereadable.
PaulS:
if(ardVal != -1)
Yes, that was the problem. Thank you :).
PaulS: Notice, too, the spaces added tomakeyourcodereadable.
It could be worse:
()p??????od?? = ???p?? ?u?
