Communication between Arduino Nano 33 IoT and UNO. Problems with Monitor Serie.
Hi Friends!
I am writing you because I have a communication problem between Arduinos. I am trying to send values from Arduino Nano 33 IoT to UNO via RX-TX. The Arduino Nano 33 IoT is the master and UNO is the slave. I tried with level shifters… I bought another Arduino Nano 33 IoT… but I cannot understand what happen.
The problem appears when I open and close the monitor serie several times. In other words, when I open the “Monitor Serie” for first time, it shows the correct value (for example 44). If I close it and open again, appear the value 137…. If I close and open other time appear the value 98…
The wiring:
• GND NANO → GND UNO
• TX NANO PIN 5 → RX UNO
• RX NANO PIN 6 → TX UNO
So, why monitor series show different values? I
Thank you very much!!
Master:
#include <Arduino.h>
#include "wiring_private.h"
Uart mySerial (&sercom0, 5, 6, SERCOM_RX_PAD_1, UART_TX_PAD_0);
// Attach the interrupt handler to the SERCOM
void SERCOM0_Handler()
    mySerial.IrqHandler();
  // Reassign pins 5 and 6 to SERCOM alt
  pinPeripheral(5, PIO_SERCOM_ALT);
  pinPeripheral(6, PIO_SERCOM_ALT);
  // Start my new hardware serial
  mySerial.begin(115200);
int prueba = 44;
 mySerial.write(prueba);
Slave:
int num;
while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB
if (Serial.available() > 0) {
 num = Serial.read();
 Serial.println(num);
