Communication between arduino uno and mysql database
I am beginner to arduino..
I have question how to communicate between Arduino Uno and PC so that i can get data from my sensors through arduino to the PC so that i can dispay it after every one minute to my database..i plan to use mysql database. What is codes that is used in pc that can take data from arduino.
Use Serial on the Arduino side. What you use on the PC side depends on what languages you are familiar/comfortable with. The Playground has a whole section on interfacing Arduinos and PCs. You need to go spend some time there.
I use a python script that receives serial data every 60 seconds from the arduino with 15 comma separated weather data points that python sends to a mysql data base. It is surprisingly easy and does not require a lot of code on the pc side.
I am actually trying to do the same... to those who answered: is it necessary to have a wifi or ethernet shield? Is there any way to connect to a local db without the need for a shield and if so how?
Edit: I am using an Arduino Uno and I am using a Mac. I am also a beginner with Arduino, though I have my degree in Comp Sci, so the programming I will be comfortable with, I've just never worked with hardware before.
Please Paul can you give me that code..i got stuck with that codes two week now and i am not good in programming
Can anyone reply to this question? because i'm also a beginner, and i'm interested if it's possible to store data into a database using just arduino Uno and mysql DB. I'm using c++ as a programming language
