Communication between Arduino+XbeeProS1 and Arduino+XbeeProS1 -
Hello Guys,
I’m trying to make 2 arduinos with Xbee Pro S1 talk each other.
Actually achieved good results, although I can’t figure out the reason for some “weird” things.
Code on Transmitter
int axisRoll = 0;
int axisPitch = 1;
const int ez_left = 7;
int rollVal;
int pitchVal;
long pulse_left, cm_left;
  pinMode(axisRoll, INPUT);
  pinMode(axisPitch, INPUT);
  pinMode(ez_left, INPUT);
  rollVal = analogRead( axisRoll );
  rollVal = map( rollVal, 305 , 600 , -90 , 90 );
  pitchVal = analogRead( axisPitch );
  pitchVal = map( pitchVal, 308, 603 , -90 , 90 );
  //  Left Sensor
  pulse_left  = pulseIn(ez_left, HIGH);
  cm_left     = ( pulse_left/147 ) * 2.54;
  Serial.println( "<"+String ( rollVal ) + "," + String ( pitchVal )  + "," + String ( cm_left )+ ">" );
  delay(200);
Code on Receiver:
char inData[50];
int index = 0;
int busy = 0;
char messageFrag;
int header = 0;
String message;
    if ( Serial.available() > 0 ) {
        messageFrag = Serial.read();
        if ( header  == 1 ) {
            inData[index] = messageFrag;
            index++;
            if ( messageFrag == 60 ) { // beggining of the message
                header = 1;
            } else if ( messageFrag == 62 ) { // end of the message
                header = 0;
                printPacket();
                inData[index] = 0;
                index++;
void printPacket() {
    for (int i = 0; i < 50; i++) {
      if ( inData[i] != 0 && inData[i] != 60 && inData[i] != 62 ) {
        Serial.print( char ( inData[i] ) );
    Serial.println("");
    index = 0;
    inData[index] = 0;
What I expect to receive at each 200ms is something like:
10,10,165
But instead, I’m receiving 4 messages followed by a waiting of 1 second approximately:
10,10,165
10,10,165
10,10,165
10,10,165
I can’t understanding why it’s not running “smooth” so any help would be really appreciate.
Thanks
Complete waste of resources. There are 7 calls to the constructor of the String class, and 5 calls to the copy constructor and 14 calls to the destructor FOR NOTHING. The XBee can’t tell that you didn’t do:
  Serial.print( "<");
  Serial.print(rollVal);
  Serial.print(",");
  Serial.print(pitchVal);
  Serial.print(",");
  Serial.print(cm_left );
  Serial.println(">" );
Is this somehow more readable to you than:
            if ( messageFrag == '<') { // beggining of the message
You never (incorrectly) write a NULL, a ‘<’ or a ‘>’ to inData, so checking for them is silly.
If you DID properly write the NULL (after each character), you could simply:
        Serial.print(inData);
No loop needed, and no silly cast of a char to a char.
Sounds like a configuration issue. It’s not a programming issue.
What are you using the data on the receiver for? Is the timing critical?
