Communication between ESP32 and MCP3551
I am trying to read RTD with MCP3551 over SPI...
Can anyone please guide me regarding any available resource for communication between ESP32 and MCP3551...
I have seen mcp3551.h file in man examples but now can't locate this file on entire google i have searched...
Will be obliged if someone can share this file to me, since there are demo examples available with this library which i can try....
Also if someone can give reference code for other 22/24 bit ADC over SPI with ESP32 then will be great guide....
Did you know that built into the ESP32 is a Sigma-delta Modulation module?
https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/peripherals/sigmadelta.html
rohimo:
You don't really need a library for this.
Looking at the datasheet probably something like this could work:
(compiles but not tested!!!)
#include "SPI.h"
union {
  int32_t val;
  uint8_t bytes[4];
} conv;
  //Initialise SPI interface
  //SPI clock speed:5MHz, Data Shift:MSB First, Data Clock Idle: SPI_MODE3 (Mode 1,1)
  SPI.beginTransaction(SPISettings(5000000, MSBFIRST, SPI_MODE3));
  digitalWrite(SS, HIGH); //set CS pin HIGH (using board's default SPI SS pin)
  Serial.println("MCP3551 Single Conversion Example...");
  //Start conversion
  digitalWrite(SS, LOW); //set CS pin LOW
  delayMicroseconds(1);
  //wait for conversion to complete
  while (digitalRead(MISO)); //wait for SDO/RDY to go low
  //read data
  conv.bytes[2] = SPI.transfer(0x00);
  conv.bytes[1] = SPI.transfer(0x00);
  conv.bytes[0] = SPI.transfer(0x00);
  //check if conversion value is negative. adjust bytes[2] and bytes[3] accordingly
  if ( (conv.bytes[2] & 0x08 == 0x08) || ((conv.bytes[2] & 0x02 == 0x02) && (conv.bytes[2] & 0x04 == 0)) ) {
    conv.bytes[2] |= 0xC0; //bits 23-22 masked
    conv.bytes[3] = 0xFF;
  else {
    conv.bytes[2] &= 0x3F; //bits 23-22 masked
    conv.bytes[3] = 0;
  //print out data
  Serial.print("Overflow HIGH (OVH): ");
  if (conv.bytes[2] & 0x04 == 0x04) Serial.println("1");
  else Serial.println("0");
  Serial.print("Overflow LOW (OVL): ");
  if (conv.bytes[2] & 0x08 == 0x08) Serial.println("1");
  Serial.print("Conversion value: ");
  Serial.println(conv.val, DEC);
  delay(1000); // Abitrary delay value for loop
hope that helps
