Communication between ESP8266 and arduino Leonardo
Hi, I connected ESP8266 with arduino Leonardo. ESP takes data from my website and it works and I want to send it to my arduino (RX TX) and it works but not correct. ESP can get only data "off" or "on" but on my monitor serial i see
O
O
O
N
O
N
O
N
O
N
O
N
O
N
O
N
O
N
O
N
O
O
O
N
My code for arduino
char nowStatus;
char prevStatus;
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11);
  pinMode(0, OUTPUT);
  while (!Serial) {}
  Serial.println("Goodnight moon!");
  mySerial.begin(115200);
  mySerial.println("Hello, world?");
  if (mySerial.available()) {
    char input = mySerial.read();
    Serial.println(input);
AND MY CODE FOR ESP
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
const char* ssid = "xxx";
const char* password = "xxx";
ESP8266WebServer server(80);
void setup(void){
  WiFi.begin(ssid, password);
void loop(void){
  HTTPClient http;    //Declare object of class HTTPClient
  String getData, Link;
  getData = "?status=current";
  Link = "http://www.example.pl/test.php" + getData;
  http.begin(Link);     //Specify request destination
  int httpCode = http.GET();            //Send the request
  String payload = http.getString();    //Get the response payload
  Serial.println(payload);    //Print request response payload
  http.end();  //Close connection
Serial.begin(115200) the same for arduino and ESP. Are you able to tell me where is the problem?
First: Always use code tags to post code! Please edit your post and insert code tags.
SoftwareSerial won't run on 115200 baud. It's not necessary as the Leonardo has a hardware serial interface on pins 0 and 1 available using the Serial1 object. Use that instead of a serial emulation.
I changed begin values and it works now without "errors". One more question (I hope last one). I want to make statement
if(answer == "OFF") {
} else if(answer == "ON") {
Just tell me please - what to put instead of "answer"?
I don't know as that depends on what the code is expected to do and surrounding code exists.
