Communication between LEDs
So, i am trying to figure out how to make two LEDs communicate with each other. More specifically, when one LED(1) is turned on, the other LED(2) will turn on, and when the LED(1) shuts off, the other LED(2) will also turn off.
// ARDUINO
//TOUCH SENSING BETA - LED TURNS ON WHEN LIGHT IS PRESENT
//BY: RICARDO DE LEMOS 1/17/2007
int led1 = 13;
int cath = 2; // negative
int ando = 3;  // positive
  pinMode(led1, OUTPUT);
  pinMode(cath, OUTPUT);
  pinMode(ando, OUTPUT);
  //REVERSE BIAS
  digitalWrite(cath, HIGH);
  digitalWrite(ando, LOW);
  //CHARGE LED
  delay(6);
  //READ LED CAP
  pinMode(ando, INPUT);
  delay(6);
  //WRITE TO LED
  if (digitalRead(ando) == LOW)
    digitalWrite(led1,HIGH);
    digitalWrite(led1,LOW);
  //RESET
And the translated version for Processing.
//Processing
//biblio
import processing.serial.*;
import cc.arduino.*;
Arduino arduino;
//variabler
int turnOnLED = 13;
int sensorP = 3;
int sensorN = 2;
//setups
void setup(){
 size (500,500);
 println(Arduino.list());
 arduino = new Arduino(this, Arduino.list()[0], 9600);
 arduino.pinMode(turnOnLED, Arduino.OUTPUT);
 arduino.pinMode(sensorP, Arduino.OUTPUT);
 arduino.pinMode(sensorN, Arduino.OUTPUT);
 //drawing
void draw(){
 //charging LED
 arduino.digitalWrite(sensorN, Arduino.LOW);
 arduino.digitalWrite(sensorP, Arduino.HIGH);
 delay(6);
 arduino.pinMode(sensorP, Arduino.INPUT);
 if(arduino.digitalRead(sensorP) == Arduino.LOW){
   background(255);
println((arduino.digitalRead(sensorP)));
println((arduino.digitalRead(sensorN)));
does this code look right?
also, is there any specific way of actually building this? Any links or suggestions would be very helpful
http://www.merl.com/papers/docs/TR2003-35.pdf
yes i did look at this, but i was hoping for some other form of references...
i think there is an issue with the code....
i'm not exactly sure what
It may be that the "digitalWrite" and "pinMode" routines are taking too long, so you're missing the conditions you're looking for - you may have to resort to direct port manipulation.
look what I did:-
http://www.thebox.myzen.co.uk/Workshop/LED_Sensing.html
how can i approach this?
I am tempted to just fix up the digital write somehow so that when the one LED on pin 13 is on and the other LED detects it, it will go on. I wish i was more code-savvy
Do you actually need to use the LED as a sensor and emitter. If not then use a normal photo sensor as LEDs while they will work are not at their most reliable doing this.
for this experiment I’m trying, yes i do want to use LEDs…I just want to see the many things i can do with this…
but anyways, in the code, i see there is Cathode and Anode, which i assume mean the anode and cathode of an LED? would it be possible if i manipulated those to do what i want?
i found something on youtube that reflects about the same idea of what i would like to do: http://www.youtube.com/user/randomskk
Yes that is what that page was showing you.
alrighty
so i think ill take this one step at a time:
my first goal would be to have the LED turn on whenever an accelerometer on the board is moved to a certain threshold.
i already made the code for it which i have here:
    Memsic2125
    Read the Memsic 2125 two-axis accelerometer.  Converts the
    pulses output by the 2125 into milli-g's (1/1000 of earth's
    gravity) and prints them over the serial connection to the
    computer.
    The circuit:
       * X output of accelerometer to digital pin 2
       * Y output of accelerometer to digital pin 3
       * +V of accelerometer to +5V
       * GND of accelerometer to ground
    http://www.arduino.cc/en/Tutorial/Memsic2125
    created 6 Nov 2008
    by David A. Mellis
    modified 30 Jun 2009
    by Tom Igoe
 // these constants won't change:
 const int xPin = 2;            // X output of the accelerometer
 const int yPin = 3;            // Y output of the accelerometer
 int LEDpin = 13;   //LED connected to digital pin 13
 int thresholdx= 100;
 int thresholdy= 100;
 // variables to read the pulse widths:
   int pulseX, pulseY;
   // variables to contain the resulting accelerations
   int accelerationX, accelerationY;
   // initialize serial communications:
   // initialize the pins connected to the accelerometer
   // as inputs:
   pinMode(xPin, INPUT);
   pinMode(yPin, INPUT);
   pinMode(LEDpin, OUTPUT);
   int pulseX, pulseY;
   // read pulse from x- and y-axes:
   pulseX = pulseIn(xPin,HIGH);
   pulseY = pulseIn(yPin,HIGH);
   // convert the pulse width into acceleration
   // accelerationX and accelerationY are in milli-g's:
   // earth's gravity is 1000 milli-g's, or 1g.
   accelerationX = ((pulseX / 10) - 500) * 8;
   accelerationY = ((pulseY / 10) - 500) * 8;
   if (accelerationX >thresholdx)
   digitalWrite(LEDpin, HIGH);
   else digitalWrite(LEDpin, LOW);
   if (accelerationY > thresholdy)
   // print the acceleration
   Serial.print(accelerationX);
   // print a tab character:
   Serial.print("\t");
   Serial.print(accelerationY);
   delay(100);
hopefully this is correct
You tell us, you have the hardware, does it work as expected?
alright an update
the code is correct! Whenever i turn the circuit board containing the accelerometer sideways, the LED lights up!
