Hi everyone,
i have got a Problem and would be very thankful about any help or idea. I am not sure if my topic is correct here but i just try to describe my problem and please let me know if have have to move it.
I am working on a Project containing five Arduino nano. One (central) is just connected to a RFM24W, each of the other four use the RFM24W plus a RTC (DS3231) and a Sensor (MS5803-07BA).
So what i want to do is using the 4 sensor to measure several stuff and send it live to my central where i get the data using Matlab. I made everything work so far an the most times i have absolutely no problem. But sometimes my central does not receive all data. So there is one of the four systems preventing another one from sending (or receiving at the central).
Example. Z is central; A,B,C,D the four systems including sensor.
A,B,C,D are turned off --> Z does not receive anything
A gets turned on --> Z receives data from A
B gets turned on --> Z receives data from A and B
C gets turned on --> Z receives data from A, B and C
D gets turned on --> Z receives data from A and B (D seems to block C from sending)
C gets turned off --> Z receives data from A, B // sometimes Z receives date from A, B and D
and sometimes even:
A,B and D are turned on --> Z receives Date from only A (D seems to block B from sending)
But when ONLY D is turned on --> Z receives data from D
So this seems like the central can not receive Data from C and D at the same time. But why does D prevent C or/and B? And what i also don't understand is it works everything fine for a few days..then for a whole day i get this Problem (not just with D, can also be A, B or C) and at the day after everything is fine again.
I use standard 434 MHz, A sends every second, B with a delay of 250 ms and so on, so all of the four will send once in a second.
I hope everyone can understand what my problem is, if something is not clearly just let me know and i will try again.
So anyone with an idea what the Problem is? Or Any Idea what i could change or try or whatever?
Thanks
Greetz Sam
