// PZEM-017 DC Energy Meter with LCD By Solarduino
// Note Summary
// Note : Safety is very important when dealing with electricity. We take no responsibilities while you do it at your own risk.
// Note : This DC Energy Monitoring Code needs PZEM-017 DC Energy Meter to measure values and Arduio Mega / UNO for communication and display.
// Note : This Code monitors DC Voltage, current, Power, and Energy.
// Note : The values shown in LCD Display is refreshed every second.
// Note : The values are calculated internally by energy meter and function of Arduino is only to read the value and for further calculation.
// Note : The first step is need to select shunt value and change the value accordingly. look for line "static uint16_t NewshuntAddr = 0x0000; "
// Note : You need to download and install (modified) Modbus Master library at our website (PZEM-014 or 016 AC Energy Meter with Arduino – A blog about DIY solar and arduino projects )
// Note : The Core of the code was from EvertDekker.com 2018 which based on the example from PZEM-016 with Arduino PZEM-014 RS485 Modbus - Solar4Living
// Note : Solarduino only amend necessary code and integrate with LCD Display Shield.
/* 1- PZEM-017 DC Energy Meter */
#include <ModbusMaster.h> // Load the (modified) library for modbus communication command codes. Kindly install at our website.
#define MAX485_DE 2 // Define DE Pin to Arduino pin. Connect DE Pin of Max485 converter module to Pin 2 (default) Arduino board
#define MAX485_RE 3// Define RE Pin to Arduino pin. Connect RE Pin of Max485 converter module to Pin 3 (default) Arduino board
// These DE anr RE pins can be any other Digital Pins to be activated during transmission and reception process.
static uint8_t pzemSlaveAddr = 0x01; // Declare the address of device (meter) in term of 8 bits. You can change to 0x02 etc if you have more than 1 meter.
static uint16_t NewshuntAddr = 0x0000; // Declare your external shunt value. Default is 100A, replace to "0x0001" if using 50A shunt, 0x0002 is for 200A, 0x0003 is for 300A
// By default manufacturer may already set, however, to set manually kindly delete the "//" for line "// setShunt(0x01);" in void setup
ModbusMaster node; /* activate modbus master codes*/
float PZEMVoltage =0; /* Declare value for DC voltage */
float PZEMCurrent =0; /* Declare value for DC current*/
float PZEMPower =0; /* Declare value for DC Power */
float PZEMEnergy=0; /* Declare value for DC Energy */
unsigned long startMillisPZEM; /* start counting time for LCD Display */
unsigned long currentMillisPZEM; /* current counting time for LCD Display */
const unsigned long periodPZEM = 1000; // refresh every X seconds (in seconds) in LED Display. Default 1000 = 1 second
int page = 1; /* display different pages on LCD Display*/
/* 2 - LCD Display */
#include<LiquidCrystal.h> /* Load the liquid Crystal Library (by default already built-it with arduino solftware)*/
LiquidCrystal LCD(48,49,4,5,6,7); /* Creating the LiquidCrystal object named LCD. The pin may be varies based on LCD module that you use*/
unsigned long startMillisLCD; /* start counting time for LCD Display */
unsigned long currentMillisLCD; /* current counting time for LCD Display */
const unsigned long periodLCD = 1000; /* refresh every X seconds (in seconds) in LED Display. Default 1000 = 1 second */
int ResetEnergy = 0; /* reset energy function */
unsigned long startMillisEnergy; /* start counting time for LCD Display */
unsigned long currentMillisEnergy; /* current counting time for LCD Display */
const unsigned long periodEnergy = 1000; // refresh every X seconds (in seconds) in LED Display. Default 1000 = 1 second
/0 General/
Serial.begin(9600); /* to display readings in Serial Monitor at 9600 baud rates */
//setShunt(0x01); // Delete the "//" to set shunt rating (0x01) is the meter address by default
// resetEnergy(0x01); // By delete the double slash symbol, the Energy value in the meter is reset. Can also be reset on the LCD Display
startMillisPZEM = millis(); /* Start counting time for run code */
Serial3.begin(9600,SERIAL_8N2); /* To assign communication port to communicate with meter. with 2 stop bits (refer to manual)*/
// By default communicate via Serial3 port: pin 14 (Tx) and pin 15 (Rx)
node.begin(pzemSlaveAddr, Serial3); /* Define and start the Modbus RTU communication. Communication to specific slave address and which Serial port */
pinMode(MAX485_RE, OUTPUT); /* Define RE Pin as Signal Output for RS485 converter. Output pin means Arduino command the pin signal to go high or low so that signal is received by the converter*/
pinMode(MAX485_DE, OUTPUT); /* Define DE Pin as Signal Output for RS485 converter. Output pin means Arduino command the pin signal to go high or low so that signal is received by the converter*/
digitalWrite(MAX485_RE, 0); /* Arduino create output signal for pin RE as LOW (no output)*/
digitalWrite(MAX485_DE, 0); /* Arduino create output signal for pin DE as LOW (no output)*/
// both pins no output means the converter is in communication signal receiving mode
node.preTransmission(preTransmission); // Callbacks allow us to configure the RS485 transceiver correctly
node.postTransmission(postTransmission);
changeAddress(0xF8,0x01); // By delete the double slash symbol, the meter address will be set as 0x01.
// By default I allow this code to run every program startup. Will not have effect if you only have 1 meter
// changeAddress(0X01, 0XF8);
delay(1000); /* after everything done, wait for 1 second */
LCD.begin(16,2); /* Tell Arduino that our LCD has 16 columns and 2 rows*/
LCD.setCursor(0,0); /* Set LCD to start with upper left corner of display*/
startMillisLCD = millis(); /* Start counting time for display refresh time*/
/* 0- General */
/* 0.1- Button Function */
int buttonRead;
buttonRead = analogRead (0); // Read analog pin A0. Pin A0 automatically assigned for LCD Display Button function (cannot be changed)
/*Right button is pressed */
if (buttonRead < 60)
LCD.setCursor(0,0); LCD.print (" PRESS <SELECT> ");
LCD.setCursor(0,1); LCD.print ("TO RESET ENERGY ");
/* Up button is pressed */
else if (buttonRead < 200)
/* Down button is pressed */
else if (buttonRead < 400)
/* Left button is pressed */
else if (buttonRead < 600)
if(ResetEnergy ==0)
if(ResetEnergy ==1) /* only to run reset energy if left button is pressed after select button*/
page = 2;
/* Select button is pressed */
else if (buttonRead < 800)
ResetEnergy = 1; // to activate offset for power
startMillisEnergy = millis(); /* start counting time for pending response*/
/* After Select button is pressed */
if(ResetEnergy ==1)
LCD.setCursor(0,0); /* set display words starting at upper left corner*/
LCD.print ("RESET ENERGY ? ");
LCD.setCursor(0,1); /* set display words starting at lower left corner*/
LCD.print ("PRESS < LEFT > ");
currentMillisEnergy = millis();
if(( currentMillisEnergy - startMillisEnergy <= 5000) && (page==2)) /* if within 5 seconds <left> button is pressed, do reset energy*/
// Reset energy
uint16_t u16CRC = 0xFFFF; /* declare CRC check 16 bits*/
static uint8_t resetCommand = 0x42; /* reset command code*/
uint8_t slaveAddr =0X01;
u16CRC = crc16_update(u16CRC, slaveAddr);
u16CRC = crc16_update(u16CRC, resetCommand);
Serial.println("Resetting Energy");
preTransmission(); /* trigger transmission mode*/
Serial3.write(slaveAddr); /* send device address in 8 bit*/
Serial3.write(resetCommand); /* send reset command */
Serial3.write(lowByte(u16CRC)); /* send CRC check code low byte (1st part) */
Serial3.write(highByte(u16CRC)); /* send CRC check code high byte (2nd part) */
delay(10);
postTransmission(); /* trigger reception mode*/
delay(100);
while (Serial3.available()) /* while receiving signal from Serial3 from meter and converter */
Serial.print(char(Serial3.read()), HEX); /* Prints the response and display on Serial Monitor (Serial)*/
Serial.print(" ");
ResetEnergy=0; /* reset command switch back to default*/
page=1; /* go back to page 1 after reset*/
if(( currentMillisEnergy - startMillisEnergy > 5000) && (page!=2)) /* if more than 5 seconds <Left> button does not pressed, go back to main page*/
currentMillisPZEM = millis(); /* count time for program run every second (by default)*/
if (currentMillisPZEM - startMillisPZEM >= periodPZEM) /* for every x seconds, run the codes below*/
uint8_t result; /* Declare variable "result" as 8 bits */
result = node.readInputRegisters(0x0000, 6); /* read the 9 registers (information) of the PZEM-014 / 016 starting 0x0000 (voltage information) kindly refer to manual)*/
if (result == node.ku8MBSuccess) /* If there is a response */
uint32_t tempdouble = 0x00000000; /* Declare variable "tempdouble" as 32 bits with initial value is 0 */
PZEMVoltage = node.getResponseBuffer(0x0000) / 100.0; /* get the 16bit value for the voltage value, divide it by 100 (as per manual) */
// 0x0000 to 0x0008 are the register address of the measurement value
PZEMCurrent = node.getResponseBuffer(0x0001) / 100.0; /* get the 16bit value for the current value, divide it by 100 (as per manual) */
tempdouble = (node.getResponseBuffer(0x0003) << 16) + node.getResponseBuffer(0x0002); /* get the power value. Power value is consists of 2 parts (2 digits of 16 bits in front and 2 digits of 16 bits at the back) and combine them to an unsigned 32bit */
PZEMPower = tempdouble / 10.0; /* Divide the value by 10 to get actual power value (as per manual) */
tempdouble = (node.getResponseBuffer(0x0005) << 16) + node.getResponseBuffer(0x0004); /* get the energy value. Energy value is consists of 2 parts (2 digits of 16 bits in front and 2 digits of 16 bits at the back) and combine them to an unsigned 32bit */
PZEMEnergy = tempdouble;
Serial.print(PZEMVoltage, 1); /* Print Voltage value on Serial Monitor with 1 decimal*/
Serial.print("V ");
Serial.print(PZEMCurrent, 3);
Serial.print("A ");
Serial.print(PZEMPower, 1);
Serial.print("W ");
Serial.print(PZEMEnergy, 0);
Serial.print("Wh ");
if (pzemSlaveAddr==2) /* just for checking purpose to see whether can read modbus*/
Serial.println("Failed to read modbus");
startMillisPZEM = currentMillisPZEM ; /* Set the starting point again for next counting time */
currentMillisLCD = millis(); /* Set counting time for LCD Display*/
if (currentMillisLCD - startMillisLCD >= periodLCD) /* for every x seconds, run the codes below*/
if( page ==1)
LCD.setCursor(0,0); /* Set cursor to first colum 0 and second row 1 */
LCD.print(PZEMVoltage, 1); /* Display Voltage on LCD Display with 1 decimal*/
LCD.print("V ");
LCD.setCursor(9,0);
LCD.print(PZEMEnergy, 0);
LCD.print("Wh ");
LCD.setCursor(0,1);
LCD.print(PZEMCurrent, 2);
LCD.print("A ");
LCD.setCursor(9,1);
LCD.print(PZEMPower, 1);
LCD.print("W ");
startMillisLCD = currentMillisLCD ; /* Set the starting point again for next counting time */
void preTransmission() /* transmission program when triggered*/
digitalWrite(MAX485_RE, 1); /* put RE Pin to high*/
digitalWrite(MAX485_DE, 1); /* put DE Pin to high*/
delay(1); // When both RE and DE Pin are high, converter is allow to transmit communication
void postTransmission() /* Reception program when triggered*/
delay(3); // When both RE and DE Pin are low, converter is allow to receive communication
digitalWrite(MAX485_RE, 0); /* put RE Pin to low*/
digitalWrite(MAX485_DE, 0); /* put DE Pin to low*/
void setShunt(uint8_t slaveAddr) //Change the slave address of a node
static uint8_t SlaveParameter = 0x06; /* Write command code to PZEM */
static uint16_t registerAddress = 0x0003; /* change shunt register address command code */
u16CRC = crc16_update(u16CRC, slaveAddr); // Calculate the crc16 over the 6bytes to be send
u16CRC = crc16_update(u16CRC, SlaveParameter);
u16CRC = crc16_update(u16CRC, highByte(registerAddress));
u16CRC = crc16_update(u16CRC, lowByte(registerAddress));
u16CRC = crc16_update(u16CRC, highByte(NewshuntAddr));
u16CRC = crc16_update(u16CRC, lowByte(NewshuntAddr));
Serial.println("Change shunt address");
Serial3.write(slaveAddr); /* these whole process code sequence refer to manual*/
Serial3.write(SlaveParameter);
Serial3.write(highByte(registerAddress));
Serial3.write(lowByte(registerAddress));
Serial3.write(highByte(NewshuntAddr));
Serial3.write(lowByte(NewshuntAddr));
delay(10);
delay(100);
Serial.print(" ");
void changeAddress(uint8_t OldslaveAddr, uint8_t NewslaveAddr) //Change the slave address of a node
static uint16_t registerAddress = 0x0002; /* Modbus RTU device address command code */
u16CRC = crc16_update(u16CRC, OldslaveAddr); // Calculate the crc16 over the 6bytes to be send
u16CRC = crc16_update(u16CRC, highByte(NewslaveAddr));
u16CRC = crc16_update(u16CRC, lowByte(NewslaveAddr));
Serial.println("Change Slave Address");
Serial3.write(OldslaveAddr); /* these whole process code sequence refer to manual*/
Serial3.write(highByte(NewslaveAddr));
Serial3.write(lowByte(NewslaveAddr));
delay(10);
delay(100);
Serial.print(" ");
I used above code but that is not work. And I connect between Rs485,DC commucation module and Arduino Mega as below photo.This code is shown "Change slave address and failed to read modulus" in Serial monitor.
