Bonjour,
je voudrais faire communiquer mon mega avec un esp01 via serial.
Jusque la, rien de bien spécial, à part que les SSID et pass changent régulièrement et que c'est impossible pour moi de faire un changement de sketch à chaque fois.
La solution (selon moi) serait d'utiliser un wifimanager.
brancheent entre esp et mega:
VCC-3,3v
MC-Pd - 3,3v
Gnd - Gnd
Tx - Rx
RX - Tx
l'esp fonctionne seul sans problèmes et le mega aussi (en insérant en manuel des ssid et pass.
Quelle est l'erreur, la solution, le coup de pouce,.... que sais-je?????
sketch esp:
#include <FS.h> // this needs to be first, or it all crashes and burns...
#include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
* this example shows how to set a static IP configuration for the ESP
* although the IP shows in the config portal, the changes will revert
* to the IP set in the source file.
* if you want the ability to configure and persist the new IP configuration
* look at the FS examples, which save the config to file
//default custom static IP
//char static_ip[16] = "10.0.1.59";
//char static_gw[16] = "10.0.1.1";
//char static_sn[16] = "255.255.255.0";
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//reset settings - for testing
//wifiManager.resetSettings();
//set static ip
//block1 should be used for ESP8266 core 2.1.0 or newer, otherwise use block2
//start-block1
//IPAddress _ip,_gw,_sn;
//_ip.fromString(static_ip);
//_gw.fromString(static_gw);
//_sn.fromString(static_sn);
//end-block1
//start-block2
IPAddress _ip = IPAddress(192, 168, 0, 150);
IPAddress _gw = IPAddress(192, 168, 0, 1);
IPAddress _sn = IPAddress(255, 255, 255, 0);
//end-block2
wifiManager.setSTAStaticIPConfig(_ip, _gw, _sn);
//tries to connect to last known settings
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP" with password "password"
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("AutoConnectAP", "password")) {
Serial.println("failed to connect, we should reset as see if it connects");
delay(3000);
ESP.restart();
delay(5000);
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
Serial.println("local ip");
Sketch mega:
//--- SETTINGS ------------------------------------------------
const char* ssid = ""; // WIFI network SSID
const char* password = ""; // WIFI network PASSWORD
int port=8000; // Virtuino default Server port
const char* serverIP = ""; // The three first numbers have to be the same with the router IP
//-------------VirtuinoCM Library and settings --------------
#include "VirtuinoCM.h"
VirtuinoCM virtuino;
#define V_memory_count 32 // the size of V memory. You can change it to a number <=255)
float V[V_memory_count]; // This array is synchronized with Virtuino V memory. You can change the type to int, long etc.
boolean debug = true; // set this variable to false on the finale code to decrease the request time.
//============================================================== setup
if (debug) {
while (!Serial) continue;
Serial1.begin(9600); // or 115200
Serial1.setTimeout(50);
virtuino.begin(onReceived,onRequested,256); //Start Virtuino. Set the buffer to 256. With this buffer Virtuino can control about 28 pins (1 command = 9bytes) The T(text) commands with 20 characters need 20+6 bytes
//virtuino.key="1234"; //This is the Virtuino password. Only requests the start with this key are accepted from the library
connectToWiFiNetwork();
pinMode(4, OUTPUT); // On Virtuino panel add a button to control this pin
pinMode(13, OUTPUT); // On Virtuino panel add a button to control this pin
pinMode(6, OUTPUT);
pinMode(7, INPUT); // On Virtuino panel add a led to get the state of this pin
//============================================================== loop
virtuinoRun(); // Necessary function to communicate with Virtuino. Client handler
vDelay(1000); // This is an example of the recommended delay function. Remove this if you don't need
//================================================ connectToWiFiNetwork
void connectToWiFiNetwork(){
Serial.println("Connecting to "+String(ssid));
while (Serial1.available()) Serial1.read();
Serial1.println("AT+GMR"); // print firmware info
waitForResponse("OK",1000);
Serial1.println("AT+CWMODE=1"); // configure as client
Serial1.print("AT+CWJAP=\""); // connect to your WiFi network
Serial1.print(ssid);
Serial1.print("\",\"");
Serial1.print(password);
Serial1.println("\"");
waitForResponse("OK",10000);
Serial1.print("AT+CIPSTA=\""); // set IP
Serial1.print(serverIP);
waitForResponse("OK",5000);
Serial1.println("AT+CIPSTA?");
waitForResponse("OK",3000);
Serial1.println("AT+CIFSR"); // get ip address
Serial1.println("AT+CIPMUX=1"); // configure for multiple connections
Serial1.print("AT+CIPSERVER=1,");
Serial1.println(port);
//============================================================== onCommandReceived
/* This function is called every time Virtuino app sends a request to server to change a Pin value
* The 'variableType' can be a character like V, T, O V=Virtual pin T=Text Pin O=PWM Pin
* The 'variableIndex' is the pin number index of Virtuino app
* The 'valueAsText' is the value that has sent from the app */
void onReceived(char variableType, uint8_t variableIndex, String valueAsText){
if (variableType=='V'){
float value = valueAsText.toFloat(); // convert the value to float. The valueAsText have to be numerical
if (variableIndex<V_memory_count) V[variableIndex]=value; // copy the received value to arduino V memory array
/* This function is called every time Virtuino app requests to read a pin value*/
String onRequested(char variableType, uint8_t variableIndex){
if (variableType=='V') {
if (variableIndex<V_memory_count) return String(V[variableIndex]); // return the value of the arduino V memory array
return "";
void virtuinoRun(){
if(Serial1.available()){
virtuino.readBuffer = Serial1.readStringUntil('\n');
if (debug) Serial.print('\n'+virtuino.readBuffer);
int pos=virtuino.readBuffer.indexOf("+IPD,");
if (pos!=-1){
int connectionId = virtuino.readBuffer.charAt(pos+5)-48; // get connection ID
int startVirtuinoCommandPos = 1+virtuino.readBuffer.indexOf(":");
virtuino.readBuffer.remove(0,startVirtuinoCommandPos);
String* response= virtuino.getResponse(); // get the text that has to be sent to Virtuino as reply. The library will check the inptuBuffer and it will create the response text
if (debug) Serial.println("\nResponse : "+*response);
if (response->length()>0) {
String cipSend = "AT+CIPSEND=";
cipSend += connectionId;
cipSend += ",";
cipSend += response->length();
cipSend += "\r\n";
while(Serial1.available()) Serial1.read(); // clear Serial1 buffer
for (int i=0;i<cipSend.length();i++) Serial1.write(cipSend.charAt(i));
if (waitForResponse(">",1000)) Serial1.print(*response);
Serial1.print("AT+CIPCLOSE=");Serial1.println(connectionId);
}// (pos!=-1)
} // if Serial1.available
//=================================================== waitForResponse
boolean waitForResponse(String target1, int timeout){
String data="";
char a;
unsigned long startTime = millis();
boolean rValue=false;
while (millis() - startTime < timeout) {
while(Serial1.available() > 0) {
a = Serial1.read();
if (debug) Serial.print(a);
if(a == '\0') continue;
data += a;
if (data.indexOf(target1) != -1) {
rValue=true;
return rValue;
//============================================================== vDelay
void vDelay(int delayInMillis){long t=millis()+delayInMillis;while (millis()<t) virtuinoRun();}
