communication issue on ISP
I have following matrix with modules on SPI arduino uno. I use also the TFT Arduino Shield. The CAN Shield is right now not connected.
  SPI                           arduino | CAN | TFT    | SD    |
  MISO  (Master In Slave Out)     12    | SO  |        | MISO  |
  MOSI  (Master Out Slave In)     11    | SI  |        | MOSI  |
  SCK   (Serial Clock)            13    | SCK |        | SCK   |
                                   7    |     | D/C    |       |
                                   6    |     | RESET  |       |
  SS/CS (Slave Select)            10    | cs  |        |       |
  SS/CS (Slave Select)             9    |     | LCD_CS |       |
  SS/CS (Slave Select)             8    |     |        | SD_CS |
So the TFT is working fine with the sketch below, but I can not read from SD card.
Serial output
Initializing SD card...failed!
Is that Pin configuration not possible as shown in the matrix?
I use this SD card already with success in arduino Yun
  Arduino TFT Bitmap Logo example
  This example reads an image file from a micro-SD card
  and draws it on the screen, at random locations.
  In this sketch, the Arduino logo is read from a micro-SD card.
  There is a .bmp file included with this sketch.
  - open the sketch folder (Ctrl-K or Cmd-K)
  - copy the "arduino.bmp" file to a micro-SD
  - put the SD into the SD slot of the Arduino TFT module.
  This example code is in the public domain.
  Created 19 April 2013 by Enrico Gueli
  http://www.arduino.cc/en/Tutorial/TFTBitmapLogo
// include the necessary libraries
#include <SPI.h>
#include <SD.h>
#include <TFT.h>  // Arduino LCD library
// pin definition for the Uno
#define sd_cs  8
#define lcd_cs 9
#define dc     7
#define rst    6
TFT TFTscreen = TFT(lcd_cs, dc, rst);
// this variable represents the image to be drawn on screen
PImage logo;
  // initialize the GLCD and show a message
  // asking the user to open the serial line
  TFTscreen.begin();
  TFTscreen.background(0, 0, 0);
  TFTscreen.stroke(255, 255, 255);
  TFTscreen.println();
  TFTscreen.println(F("Arduino TFT Bitmap Example"));
  TFTscreen.println(F("Open serial monitor"));
  TFTscreen.println(F("to run the sketch"));
  // initialize the serial port: it will be used to
  // print some diagnostic info
  Serial.begin(250000);
  while (!Serial) {
    // wait for serial port to connect. Needed for native USB port only
  delay(10000);
  // clear the GLCD screen before starting
  // try to access the SD card. If that fails (e.g.
  // no card present), the setup process will stop.
  Serial.print(F("Initializing SD card..."));
  if (!SD.begin(sd_cs)) {
    Serial.println(F("failed!"));
    return;
  Serial.println(F("OK!"));
  // initialize and clear the GLCD screen
  TFTscreen.begin();
  // now that the SD card can be access, try to load the
  // image file.
  logo = TFTscreen.loadImage("logo.bmp");
  if (!logo.isValid()) {
    Serial.println(F("error while loading arduino.bmp"));
  // don't do anything if the image wasn't loaded correctly.
  if (logo.isValid() == false) {
    return;
  Serial.println(F("drawing image"));
  // get a random location where to draw the image.
  // To avoid the image to be draw outside the screen,
  // take into account the image size.
  int x = random(TFTscreen.width() - logo.width());
  int y = random(TFTscreen.height() - logo.height());
  // draw the image to the screen
  TFTscreen.image(logo, x, y);
  // wait a little bit before drawing again
  delay(1500);
Thanks for your help.
I started from scratch and reconnected all wire with arduino uno and the arduino TFT shield
describes here:
and with following original example sketch:
#include <SPI.h>
#include <SD.h>
#define sd_cs  4
#define lcd_cs 10
#define dc     9
#define rst    8
// pin definition for the Leonardo
//#define sd_cs  8
//#define lcd_cs 7
//#define dc     0
//#define rst    1
PImage logo;
  TFTscreen.begin();
  TFTscreen.background(255, 255, 255);
  TFTscreen.stroke(0, 0, 255);
  TFTscreen.stroke(0, 0, 0);
  while (!Serial) {
    return;
  TFTscreen.begin();
  // image file.
  logo = TFTscreen.loadImage("arduino.bmp");
    return;
  delay(1500);
...and get still the failure. :cold_sweat:
I have no personal experience but there have been several Threads recently about problems trying to get another SPI device to work with an SD Card. This is one example that I bookmarked.
...R
THX Robin2,
thanks for the Link and I found also some more posts.
The point is also that the TFT Shield with the SD card slot from arduino is not working at all. :frowning:
