we have a project where we use an Arduino Mega 2560 for datalogging. The
arduino sends
periodically (2s cycle) a string containing different sensor values.
Our problem is that logview hangs up from time to time. The serial
logging stops can't open the COM-Port anymore but the UART from the Atmega2560 to the Atmerga16U2 is still sending.
The only solution is to unplug and reconnect the USB-cable. Unfortunately, this isn't an acceptable solution for us.
What we have tried so far:
- We removed all sensors/actors from the Arduino Mega 2560 and sent only
dummy strings over USB -> log still hangs up - We reduced the baudrate --> still hangs up
- We used shorter USB-cables --> still hangs up
- We used on the PC a simple PC-program writing serial data to a file
(instead of logview) --> also hangs up - We connected an additional arduino USART/USB converter to the second
USART from the Arduino and sent the same strings over both UARTS. On PC
we watched both ports with logview and putty -> both hanged up - We tested this also with different PC's.
Our OS Debian.
You have any idea? We think that it could be
- problem with ground
Best regards
