Hello everyone,
I have a communication issue between an Arduino Uno and an ESP8266 connected to the Arduino Cloud.
The Uno measures several variables (temperature, conductivity, pH, as well as 4 liquid levels). It also regulates pH and conductivity by receiving a setpoint for each from the ESP8266 via a Dashboard.
The ESP8266 receives all the values and displays them on a Dashboard, and the user can change the setpoints and so on.
When the communication (serial via pins 1 and 2) is one-way, it works fine. However, as soon as it needs to be bidirectional, I don't receive anything.
I feel like I've tried everything and I'm a bit lost.
Here are my codes:
ESP8266 :
#include "thingProperties.h"
// Initialize serial and wait for port to open:
delay(1500);
consigne_ph = 8.0; // Consigne de pH
consigne_conductivite = 2000.0; // Consigne de conductivité
initProperties();
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Envoyer les valeurs de consigne pH et conductivité à l'autre Arduino
Serial.print(consigne_ph);
Serial.print(",");
Serial.print(consigne_conductivite);
// Attendre la réponse de l'autre Arduino
while (Serial.available() == 0) {
delay(10);
// Lire les valeurs renvoyées par l'autre Arduino
String data = Serial.readStringUntil('\n');
int separatorIndex = data.indexOf(',');
if (separatorIndex != -1) {
float ph = data.substring(0, separatorIndex).toFloat();
float conductivite = data.substring(separatorIndex + 1).toFloat();
float temperature = data.substring(separatorIndex + 1, data.indexOf(',', separatorIndex + 1)).toFloat();
bool niveau_A = data.substring(data.indexOf(',', separatorIndex + 1) + 1, data.indexOf(',', separatorIndex + 1 + 1)).toInt();
bool niveau_B = data.substring(data.indexOf(',', separatorIndex + 1 + 1) + 1, data.indexOf(',', separatorIndex + 1 + 2)).toInt();
bool niveau_C = data.substring(data.indexOf(',', separatorIndex + 1 + 2) + 1, data.indexOf(',', separatorIndex + 1 + 3)).toInt();
bool niveau_D = data.substring(data.indexOf(',', separatorIndex + 1 + 3) + 1).toInt();
delay(10000);
Since ConsignePh is READ_WRITE variable, onConsignePhChange() is
executed every time a new value is received from IoT Cloud.
void onConsignePhChange() {
// Add your code here to act upon ConsignePh change
Since ConsigneConductivite is READ_WRITE variable, onConsigneConductiviteChange() is
void onConsigneConductiviteChange() {
// Add your code here to act upon ConsigneConductivite change
Arduino UNO :
float consigne_ph; // Consigne de pH reçue
float consigne_conductivite; // Consigne de conductivité reçue
if (Serial.available() > 0) {
// Lire les valeurs de consigne de pH et conductivité envoyées par l'autre Arduino
consigne_ph = data.substring(0, separatorIndex).toFloat();
consigne_conductivite = data.substring(separatorIndex + 1).toFloat();
// Traiter les données et simuler les valeurs de température et niveaux
float ph = consigne_ph+0.5;
float conductivite = consigne_conductivite+500;
float temperature = 25.0; // Simulation de la valeur de température
bool niveau_A = random(0, 2); // Générer une valeur aléatoire pour le niveau A (0 ou 1)
bool niveau_B = random(0, 2); // Générer une valeur aléatoire pour le niveau B (0 ou 1)
bool niveau_C = random(0, 2); // Générer une valeur aléatoire pour le niveau C (0 ou 1)
bool niveau_D = random(0, 2); // Générer une valeur aléatoire pour le niveau D (0 ou 1)
// Envoyer les valeurs de pH, conductivité, température et niveaux
Serial.print(ph);
Serial.print(",");
Serial.print(conductivite);
Serial.print(",");
Serial.print(temperature);
Serial.print(",");
Serial.print(niveau_A);
Serial.print(",");
Serial.print(niveau_B);
Serial.print(",");
Serial.print(niveau_C);
Serial.print(",");
Serial.println(niveau_D);
delay(5000);
Thank you very much !
