Elis:
Common error with a small difference. You check for serial to have 2 characters available (instead of the usual 1 character that available() > 0 ensures) and then you read more than 2 times.Arduino is very much faster than serial data arrives. Perhaps > 1 should be >= characters to be read?
while (Serial.available() > 1){
//lee el terminal
terminal1 = Serial.read();
terminal1 = (terminal1 - 48)*10;
terminal2 = Serial.read();
terminal2 = terminal2 - 48 + terminal1;
delay(5); //espera para que le lleguen todos los datos antes de leerlos
if ( terminal2 == 5){
//LEDS
//lee la tension
tension1 = Serial.read();
tension1 = (tension1 - 48)*100;
tension2 = Serial.read();
tension2 = (tension2 - 48)10 + tension1;
tension3 = Serial.read();
tension3 = 2(tension3 - 48 + tension2);
analogWrite(terminal2, tension3);
else{
//servos
pos1 = Serial.read();
pos1 = (pos1 - 48)*100;
pos2 = Serial.read();
pos2 = (pos2 - 48)*10 + pos1;
pos3 = Serial.read();
pos3 = (pos3 - 48) + pos2;
pos_f = (float)pos3/100.0 * max_ang;
g_servo8.write(pos_f);
}//end while
