Hi everybody,
i’m new in the forum so i apologize if this is not the correct place for the thread.
The thing is i’m trying to program some dynamixels AX-12A. (I have 5 in my possession now)
One of them is working properly and I can use it without problem.
The thing is I can’t communicate with the others (all of them have been used before so maybe the ID number is changed). So i try to reset them with the function
Dynamixel.reset(254)
since 254 seems to be the number to access all the AX.12A, and i also tried it with:
for (int i=0; i<255; i++){
Dynamixel.reset(i);
The one i can communicate with resets with this commands (i know it because the leds blink when you reset them), but i’m not able to reset the others.
Currently im using a baud rate of 1x10^6. Can it be a baud rate problem?
Is there a way to “protect from resets”, so they may have been protected before I got them?
I runned out of ideas and I have no clue how to solve this.
The code i’m using is:
#include <DynamixelSerial.h>
void setup(){
Dynamixel.begin(1000000);
Dynamixel.reset(i);
//for (int i=0; i<254; i++){
//Dynamixel.setID(i,1);
// Dynamixel.ledStatus(1,ON);
void loop(){
//Dynamixel.moveSpeed(1,512, 750); // Mueve el Servo a la Posición 750 con una Velocidad de 1023
//delay(2000);
//Dynamixel.moveSpeed(1,1023, 750);
//delay(4999);
//Dynamixel.ping(1);
Dynamixel.moveSpeed(254,200, 750);
delay(2000);
Dynamixel.moveSpeed(254,800, 750);
delay(3000);
