Communication problem with nRF24L01. Do not send "sent response"
I installed the nRF24L01 modules. I use the library RF24, 2 modules nRF24L01 with base and 2 Uno R3. I started with the example of the library GetStarted. The instructions are on http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo#lib and here is the code:
* Getting Started example sketch for nRF24L01+ radios
* This is a very basic example of how to send data from one node to another
* Updated: Dec 2014 by TMRh20
#include <SPI.h>
#include "RF24.h"
/****************** User Config ***************************/
/***      Set this radio as radio number 0 or 1         ***/
bool radioNumber = 1;
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
RF24 radio(7,8);
byte addresses[][6] = {"1Node","2Node"};
// Used to control whether this node is sending or receiving
bool role = 0;
  Serial.println(F("RF24/examples/GettingStarted"));
  Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
  radio.begin();
  // Set the PA Level low to prevent power supply related issues since this is a
 // getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
  radio.setPALevel(RF24_PA_LOW);
  // Open a writing and reading pipe on each radio, with opposite addresses
  if(radioNumber){
    radio.openWritingPipe(addresses[1]);
    radio.openReadingPipe(1,addresses[0]);
  }else{
    radio.openWritingPipe(addresses[0]);
    radio.openReadingPipe(1,addresses[1]);
  // Start the radio listening for data
  radio.startListening();
/****************** Ping Out Role ***************************/
if (role == 1)  {
    radio.stopListening();                                    // First, stop listening so we can talk.
    Serial.println(F("Now sending"));
    unsigned long start_time = micros();                             // Take the time, and send it.  This will block until complete
     if (!radio.write( &start_time, sizeof(unsigned long) )){
       Serial.println(F("failed"));
    radio.startListening();                                    // Now, continue listening
    unsigned long started_waiting_at = micros();               // Set up a timeout period, get the current microseconds
    boolean timeout = false;                                   // Set up a variable to indicate if a response was received or not
    while ( ! radio.available() ){                             // While nothing is received
      if (micros() - started_waiting_at > 200000 ){            // If waited longer than 200ms, indicate timeout and exit while loop
          timeout = true;
    if ( timeout ){                                             // Describe the results
        Serial.println(F("Failed, response timed out."));
    }else{
        unsigned long got_time;                                 // Grab the response, compare, and send to debugging spew
        radio.read( &got_time, sizeof(unsigned long) );
        unsigned long end_time = micros();
        // Spew it
        Serial.print(F("Sent "));
        Serial.print(start_time);
        Serial.print(F(", Got response "));
        Serial.print(got_time);
        Serial.print(F(", Round-trip delay "));
        Serial.print(end_time-start_time);
        Serial.println(F(" microseconds"));
    // Try again 1s later
/****************** Pong Back Role ***************************/
  if ( role == 0 )
    if( radio.available()){
        // Variable for the received timestamp
      while (radio.available()) {                                   // While there is data ready
        radio.read( &got_time, sizeof(unsigned long) );             // Get the payload
      radio.write( &got_time, sizeof(unsigned long) );              // Send the final one back.
      radio.startListening();                                       // Now, resume listening so we catch the next packets.
      Serial.print(F("Sent response "));
      Serial.println(got_time);
/****************** Change Roles via Serial Commands ***************************/
  if ( Serial.available() )
    char c = toupper(Serial.read());
    if ( c == 'T' && role == 0 ){
      Serial.println(F("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK"));
      role = 1;                  // Become the primary transmitter (ping out)
   }else
    if ( c == 'R' && role == 1 ){
      Serial.println(F("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
       role = 0;                // Become the primary receiver (pong back)
} // Loop
I habe some communication problem. When card Nr 1 is set as transmitter and card Nr 0 as receiver
the card Nr 0 don't send any response:
Card Nr1
Now sending
failed
Now sending
Card Nr0
When I switch (NR 1 as receiver, Nr 0 as transmitter), I get:
Card Nr1
Sent response 8
Sent response 9472
Sent response 9472
Sent response 19202048
Card Nr0
Now sending
failed
Now sending
Any guess?
Pictures / detail on how things are wired and powered would help
The modules are wired this way:
Base Uno
GND GND *
VCC 3.3V *
CE 9
CSN 10
SCK 13
MOSI 11
MISO 12
IRQ 2
I now get
Card 1
ow sending
Now sending
Sent 137212992, Got response 0, Round-trip delay 21628 microseconds
Now sending
Card Nr0
I habe a problem a wire for Card 1, but card 0 didn#t sent any response at all, which is weird as well.
Anyone? :slight_smile:
just for trying out change
      if (micros() - started_waiting_at > [color=red]200000[/color] ){            // If waited longer than 200ms, indicate timeout and exit while loop
into
      if (micros() - started_waiting_at > [color=green]1000000ul[/color] ){            // If waited longer than 1s, indicate timeout and exit while loop
see if you get a different result
also are you using a Socket Adapter Board For 8PIN NRF24L01
it offers a 3.3V regulator.
you might need otherwise a cap across pins 1 and 2 for a juice boost otherwise
This Simple nRF24L01+ Tutorial may be helpful.
...R
@J-M-L: I use the base you showed. The problem of power supply can be set aside.
I changed the code, but I still get for both cards (alternatively):
Now sending
failed
did you use one of Robin's example code?
medeslip:
Now sending
failed
I deliberately kept my examples simpler to avoid that sort of confusion.
...R
I tried your tutorial. I think this is much simpliers indeed. I got data received on one hand and data sent on the other hand, but I wonder why I still get data received when I just plug one card in?
M.
Not sure I understand your question.. you might have a module with a poor antenna or GND insulation and with which your reception ability will vary - do you have more than 2 modules?
I have two modules and the transmitter successgully sends messages to the receiver according to the simple script of the tutorial. Then I tested the error message. I just used the receiver module. It shouldn t receive any message because the transmitter is not used. But the serial tab shows message received! I think this is not possible. Why do I see this?
medeslip:
Please post the exact programs that YOU uploaded to your Arduinos and post the output that you get when the transmitter Arduino is not powered up.
...R
I uploaded this code:
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN);
char dataReceived[10]; // this must match dataToSend in the TX
int ackData[2] = {109, -4000}; // the two values to be sent to the master
bool newData = false;
    Serial.println("SimpleRxAckPayload Starting");
    radio.begin();
    radio.setDataRate( RF24_250KBPS );
    radio.openReadingPipe(1, thisSlaveAddress);
    radio.enableAckPayload();
    radio.writeAckPayload(1, &ackData, sizeof(ackData)); // pre-load data
    getData();
    showData();
void getData() {
    if ( radio.available() ) {
        radio.read( &dataReceived, sizeof(dataReceived) );
        updateReplyData();
        newData = true;
void showData() {
    if (newData == true) {
        Serial.print("Data received ");
        Serial.println(dataReceived);
        Serial.print(" ackPayload sent ");
        Serial.print(ackData[0]);
        Serial.print(", ");
        Serial.println(ackData[1]);
        newData = false;
void updateReplyData() {
    ackData[0] -= 1;
    ackData[1] -= 1;
    if (ackData[0] < 100) {
        ackData[0] = 109;
    if (ackData[1] < -4009) {
        ackData[1] = -4000;
    radio.writeAckPayload(0, &ackData, sizeof(ackData)); // load the payload for the next time
And I received this:
þSimpleRx Starting
Data received
Data received
An now the tricky part: without plugging in the master card. One card-> data received :slight_smile:
I also have communication problems with two cards.
Here the code on the transmitter:
// SimpleTxAckPayload - the master or the transmitter
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
int ackData[2] = {-1, -1}; // to hold the two values coming from the slave
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
    Serial.println(F("Source File /mnt/sdb1/SGT-Prog/Arduino/ForumDemos/nRF24Tutorial/SimpleTxAckPayload.ino"));
    Serial.println("SimpleTxAckPayload Starting");
    radio.begin();
    radio.setRetries(3,5); // delay, count
    radio.openWritingPipe(slaveAddress);
    currentMillis = millis();
    if (currentMillis - prevMillis >= txIntervalMillis) {
        send();
    showData();
void send() {
    bool rslt;
    rslt = radio.write( &dataToSend, sizeof(dataToSend) );
        // Always use sizeof() as it gives the size as the number of bytes.
        // For example if dataToSend was an int sizeof() would correctly return 2
    Serial.print("Data Sent ");
    Serial.print(dataToSend);
    if (rslt) {
        if ( radio.isAckPayloadAvailable() ) {
            radio.read(&ackData, sizeof(ackData));
            newData = true;
        else {
            Serial.println("  Acknowledge but no data ");
        updateMessage();
    else {
        Serial.println("  Tx failed");
    prevMillis = millis();
void showData() {
        Serial.print("  Acknowledge data ");
        Serial.print(", ");
        newData = false;
void updateMessage() {
        // so you can see that ew data is being sent
    txNum += 1;
    if (txNum > '9') {
        txNum = '0';
    dataToSend[8] = txNum;
And I get:
It works fine until the loop actually.
Actually I must upload the code to be able to open the Serial tab. If the card was flashed earlier and I open the IDE, I can't open the serial tab.
The code of the receiver is:
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
    Serial.println("SimpleRx Starting");
    radio.begin();
    getData();
    showData();
void getData() {
        newData = true;
void showData() {
        newData = false;
And I get:
`åSimpleRx Starting
Data received
My understanding is that the radio link works, but no date is sent. What could it be?
Referring to Reply #15....
My tutorial examples are designed to work in pairs. So SimpleTxAckPayload should be tried only with SimpleRxAckPayload.
Referring to Reply #14...
If you are getting the response you say with only one nRF24 powered up I strongly suspect there is something wrong either your connections or (more likely) with the nRF24 itself.
When I tried your code on my Uno it printed "SimpleRxAckPayload Starting" and nothing else - which is the expected behaviour.
Do you get the same result when you try that code with your other nRF24?
...R
#15 was a bad copy paste. The codes matches with each other.
For the transmiter I used:
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
char txNum = '0';
    Serial.println("SimpleTx Starting");
    radio.begin();
        send();
void send() {
    bool rslt;
    if (rslt) {
        Serial.println("  Acknowledge received");
        updateMessage();
    else {
        // so you can see that new data is being sent
    txNum += 1;
    if (txNum > '9') {
        txNum = '0';
and I get:
SimpleTx Starting
For the receiver I used:
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   9
#define CSN_PIN 10
    radio.begin();
    getData();
    showData();
void getData() {
        newData = true;
void showData() {
        newData = false;
And I get
0SimpleRx Starting
Data received
Data received
Data received
If I take the NRF24L01 off the module base, I get:
SimpleTx Starting
Data Sent Message 0 Acknowledge received
Data Sent Message 1 Acknowledge received
Data Sent Message 2 Acknowledge received
How can I test the connection? Why is there any message sent by the transmitter?
I did this tutorial:
https://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-ExampleSketches#js1
I applied this wiring:
1 - GND
2 - VCC 3.3V !!! NOT 5V
3 - CE to Arduino pin 7
4 - CSN to Arduino pin 8
5 - SCK to Arduino pin 13
6 - MOSI to Arduino pin 11
7 - MISO to Arduino pin 12
For the code, see the tuto.
I get :
YourDuino.com Example: Send joystick data by nRF24L01 radio to another Arduino
Now sending - Response timed out - no Acknowledge
and
and YourDuino.com Example: Receive joystick data by nRF24L01 radio from another Arduino
and control servos if attached (Check 'hasHardware' variable
But it works when I take out and back in the wire MISO:
first card:
Now sending - Sent 337664560, Got response 2048, Round-trip delay 337662512 microseconds
second card:
Packet Received - Sent response 0uS X= 0 Y= 0 Switch OFF
When the wire is set, it doesn#t work, when it is not, it works for some seconds. Why?
Can you please post the problem code here.
