Hello
I'm using a Arduino w/ ATMega 328. I'v been able to upload a program to the arduino before, but suddenly it failed the attempt and gave me this error:
avrdude: stk500_getsync(): not in sync: resp=0x00
I know that i've chosen the right board in the "tools" menu, but my serial port is always COM1, even though nothing is connected. When i change usb port
on my computer, it still is at COM1.
Tried to look up similar problems, but it seems they are kind of different.
Thank you for any feedback!
In Tools-> Board, make sure you've selected the right board.
You already said you checked the COM port, so no worries on that.
If you have any devices connected to the arduino, unplug them before you upload,
unplug EVERYTHING and close the IDE
plug everything back in and start the IDE back up
if that doesn't work,
try hitting the reset RIGHT before you hit upload (if you have a reset button)
and if that STILL doesn't work,
unplug your board from the USB connection, and hit upload (this might not make sense, but wait)
when the application does that "Binary sketch size blah blah" thing, plug it back in.
if that doesn't work, your problems are worse than mine were.
Good luck.
EDIT: Misinterpreted your COM issue. Try everything I suggested, but also try reinstalling the driver.
