Communication problems with the Arduino Mega 2560 with the DHT-11 sensor.
I have the 2560 mega arduino kit and want to communicate with the DHT-11 temperature sensor.
I downloaded his library and insert it into the libraries of my compiler.
I made the following command lines:
#include <dht.h>
#define dht_dpin A5
dht DHT;
void setup () {
Serial.begin (9600);
delay (1000);
void loop () {
DHT.read11 (dht_dpin);
Serial.print ("Humidity:");
Serial.print (DHT.humidity);
Serial.println ("%");
Serial.print (DHT.temperature);
Serial.print ("Celsius");
delay (2000);
The following message appeared:
WARNING: The DHTlib library claims to run on architecture (s) (atmelavr) and may be incompatible with your current board, which runs in architecture (s) (avr).
The sketch uses 4772 bytes (1%) of storage space for programs. The maximum is 253952 bytes.
Global variables use 235 bytes (2%) of dynamic memory, leaving 7957 bytes for local variables. The maximum is 8192 bytes.
Is this sensor incompatible with my mega arduino 2560?
Post a link to the DHT library you're using! There are about a dozen of them. And learn to use code tags!
The link where I downloaded the library was this: https://portal.vidadesilicio.com.br/wp-content/uploads/2017/05/DHTlib.zip
atmelavr and avr are the same platforms. I guess the renaming occurred because Microchip acquired Atmel some time ago. The author explicitly states that the library runs on a Mega2560.
Does the sketch work for you? Otherwise: how did you connect the DHT to the Arduino? Wiring diagram?
The electrical connection I made correctly. I will download other libraries and go testing to see if I can communicate.
