Communication problems
Hey there,
i have written an programm to communicate between my PC and the Arduino Ethernet. But after a few successful conections, something break and the board accept no connections. (Timeout). Is there a mistake in my code?
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0xDD, 0x5C };
byte ip[] = { 192, 168, 87, 201 };
byte gateway[] = { 192, 168, 87, 254 };
byte subnet[] = { 255, 255, 255, 0 };
int val = 0;
EthernetServer server(8765);
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  pinMode(0, OUTPUT);
  pinMode(1, OUTPUT);
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, INPUT);
  pinMode(7, INPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  /*pinMode(10, INPUT);
  pinMode(11, INPUT);*/
  // if an incoming client connects, there will be bytes available to read:
  if (client == true)
    byte input = client.read();
    if(input == 110) //Tor 1 Hoch
      digitalWrite(0, HIGH);
      digitalWrite(0, LOW);
      server.write(input);
    else if(input == 111) //Tor 1 Runter
      digitalWrite(1, HIGH);
      digitalWrite(1, LOW);
    else if(input == 112) //Tor Status Up
      val = digitalRead(2);
      if(val == HIGH)
        server.write(200);
        server.write(100);
    else if(input == 113) //Tor Status Down
      val = digitalRead(3);
      if(val == HIGH)
        server.write(200);
        server.write(100);
    else if(input == 120) //Tor 2 Hoch
      digitalWrite(4, HIGH);
      digitalWrite(4, LOW);
    else if(input == 121) //Tor 2 Runter
      digitalWrite(5, HIGH);
      digitalWrite(5, LOW);
    else if(input == 122) //Tor Status Up
      val = digitalRead(6);
      if(val == HIGH)
        server.write(200);
        server.write(100);
    else if(input == 123) //Tor Status Down
      val = digitalRead(7);
      if(val == HIGH)
        server.write(200);
        server.write(100);
    else if(input == 130) //Tor 3 Hoch
      digitalWrite(8, HIGH);
      digitalWrite(8, LOW);
    else if(input == 131) //Tor 3 Runter
      digitalWrite(9, HIGH);
      digitalWrite(9, LOW);
      server.write(44);
You are not closing the connections, so you should run out of sockets after 4 connections. The last thing you should do is close the connection.
  client.stop();
You should use the client.write() calls instead of server.write().
It has no error checking like timeout, but it should work more than just 4 times.
  if (client == true)
client will never equal true.
Then, whether the client has sent anything, or not, you read exactly one byte from the client. You never close the client connection, so, after 4 successful connections, the 4 sockets are all in use, and no more clients can connect.
Yes, you are doing something (more than one something, actually) wrong.
Look at how the example server code works, and how much stuff you left out.
Now it works. Thanks a lot!
