Communication with a HC-05 Master
I would like a guidance on a feasibility of one project.
I need to have two arduino talking to each other over bluetooth (HC-05).
I guess this is not the hardest part, there is a lot of tutorial to put one in slave and one in master.
But I also would like to be able to see the communication on my PC/Android. So the schema would be something like :
PC <----> HC-05 Master <----> HC-05 Slave
Where PC can receive (and send if possible), HC-05 Master can send and receive, and HC-05 Slave can send.
Is it possible ?
Should I use my PC/smartphone as a Slave ?
Thanks
Irrespective of the device and who is master and who is slave, you are implying bluetooth<>bluetooth<>bluetooth. This means the bluetooth in the middle is communicating with two different devices. This is possible but charitably described as tedious.
I submit you are better off paying the money and getting another HC-05 , thereby enabling you to use the devices in a conventional manner. This means an Arduino communicates with another via one bluetooth and the Android via another.
I doubt that the phone can operate as a slave, and there is no good reason for it to do so.
Thank you Nick,
If I understand well, you suggest me to do this? :
Phone BT Master <---> HC-05 Slave : Arduino : HC-05 Master <---> HC-05 Slave : Arduino
If yes, how one arduino can communicate with two different HC-05?
Yes
Serial.print("Hello Android");
Serial1.print("Hello Other Arduino");
where Serial1 is either another hardware serial port on a Mega, or is a software serial configuration on a Uno or the like.
Is it possible on a Arduino Pro Mini ?
How do you create a "software serial" ? Any ressources ?
Thanks
EDIT: Just found this : https://www.arduino.cc/en/Reference/SoftwareSerial
EDIT2: I've made it work with three HC-05 modules and a combination of these three tutorials :
https://arduino-info.wikispaces.com/BlueTooth-HC05-HC06-Modules-How-To
http://elasticsheep.com/2011/05/serial-bluetooth-module-masterslave-connection/
thanks again !
