communication with Bluetooth terminal but not with switch
Hello,
I have copied a sketch, as I am a beginner and trying to operate it with Bluetooth switch from my phone but its not working but via Bluetooth terminal it is working well.Please kindly HELP!!
#include<SoftwareSerial.h>
#define IN1 12
#define IN2 11
#define IN3 10
#define IN4 9
//#define EN1 6
//#define EN2 5
SoftwareSerial mySerial(2, 3); // RX, TX
String data;
int btVal;
 //Serial.begin(115200);
 pinMode(IN1, OUTPUT);
 pinMode(IN2, OUTPUT);
 pinMode(IN3, OUTPUT);
 pinMode(IN4, OUTPUT);
 //pinMode(EN1, OUTPUT);
 //pinMode(EN2, OUTPUT);
 digitalWrite(IN1, LOW);
 digitalWrite(IN2, LOW);
 digitalWrite(IN3, LOW);
 digitalWrite(IN4, LOW);
 //analogWrite(EN1,63);
 //analogWrite(EN2,63);
 mySerial.begin(9600);
 while (mySerial.available())
 data = mySerial.readStringUntil('\n');
 //Serial.print(str);
 btVal = (data.toInt());
 //Serial.print("BlueTooth Value ");
 //Serial.println(btVal);
 switch (btVal)
 case 1:
 //Serial.println("Forward");
 forward();
 case 2:
 //Serial.println("Reverse");
 reverse();
 case 3:
 //Serial.println("Left");
 left();
 case 4:
 //Serial.println("Right");
 right();
 case 5:
 //Serial.println("Stop");
 stoprobot();
 if (mySerial.available() < 0)
 //Serial.println("No Bluetooth Data ");
void forward()
 digitalWrite(IN1, HIGH);
 digitalWrite(IN3, HIGH);
void reverse()
 digitalWrite(IN2, HIGH);
 digitalWrite(IN4, HIGH);
void left()
void right()
void stoprobot()
Are you sure your phone is sending a ‘\n’ at the end like the terminal was?
No I don’t think so ...How can I do that .please help !!
I have no idea how bluetooth switch works on your phone. You could also alter your code so it simply reads in a single char and acts upon that rather than reading until ‘\n’ and then converting to an integer.
This will change your case statements to use char rather than an int
#define IN1 12
#define IN2 11
#define IN3 10
#define IN4 9
//#define EN1 6
//#define EN2 5
  if (mySerial.available())
    chat data = mySerial.read();
    switch (data)
      case '1':
        forward();
      case '2':
        reverse();
      case '3':
        left();
      case '4':
        right();
      case '5':
        stoprobot();
void forward()
void reverse()
void left()
void right()
void stoprobot()
Thanks blh64 for your concern and support.
