Communication with nrf24 with using Arduino Nano
We try to make a communication bridge (joystick-drone-rover) with nRF24 and arduinos. We want to send signal to the rover from the joystick (control) with using the nRF24 on drone between them. The drone carries the rover. We have the codes of joystick as receiver ardiuno and codes of arduino that connect to the rover's motor. In this sutiation we have drone in the middle between them and it has nRF24 and Arduino nano. We cant figure out that the drone code that carry the transmitter code of joystick to the arduino that connect to the rover's motor. Could you help me?
Sorry, Can not figure out what you are doing with a SINGLE nrf24. Please post a block diagram drawing of what you are planning and show lines connecting where the communications are needed.
Paul
We are using 3 nrf24, we need to communicate joystick with motors using the drone between them. Drone has nano and nrf24 also there is quick representation figure here. We have the joystick codes but how to send them to the motors with the help of drone, we couldnt find it.
Why have you designed this way rather than using nrf24 higher power version?
Paul
added: It's called "bilateral store and forward" and is used by NASA to communicate between orbiting satellites and the earth.
You will need to develop a very robust communications protocol to ensure each message gets to it's final destination and the sending device is assured that the message was delivered.
Unless you are getting paid by the hour, you will soon give up and find a new hobby.
