Communication with two XBee's and Arduinos over serial
I have 2 XBees connected to 2 arduino UNOs. Here is the X-CTU config:
[i]XBee 1[/i]
Pan ID = 4270
DL = 10
MY = 20
[i]XBee 2[/i]
Pan ID = 4270
DL = 20
MY = 10
[i]Both[/i]
DD = 10000
IC = FF
IR = 32
My project is making a turn signal system for a bicycle. The front of the bike will house one arduino, and the back will hold the other. In the front there are two turn signals, and a switch to turn each one on or off. I want this arduino to send this switch/turn signal data wirelessly (look at the interrupts in the front arduino code). I also want to receive data from a proximity sensor in the rear. The code is posted below.
Front:
#include <avr/io.h>
#include <avr/interrupt.h>
bool leftBlink, rightBlink;  //turn signal variables
void setup(){
    attachInterrupt(0, leftPress, CHANGE);  //setup left turn signal interrupt
    attachInterrupt(1, rightPress, CHANGE);  //setup right turn signal interrupt
    noInterrupts();
    TCCR1A = 0;     // set entire TCCR1A register to 0
    TCCR1B = 0;     // same for TCCR1B
    // set compare match register to desired timer count:
    OCR1A = 15624;
    // turn on CTC mode:
    TCCR1B |= (1 << WGM12);
    // Set CS10 and CS12 bits for 1024 prescaler:
    TCCR1B |= (1 << CS10);
    TCCR1B |= (1 << CS12);
    // enable timer compare interrupt:
    TIMSK1 |= (1 << OCIE1A);
    interrupts();
    leftBlink = false;
    rightBlink = false;
    pinMode(2,INPUT);  //Left turn signal input
    pinMode(3,INPUT);  //Right turn signal input
    pinMode(4,OUTPUT);  //555 timer for ttl relays, left blinker
    digitalWrite(4,HIGH);  //Keep high so blinker doesn't blink
    pinMode(5,OUTPUT);  //555 timer for ttl realys, right blinker
    digitalWrite(5,HIGH);  //Keep high
    pinMode(6,OUTPUT);  //Prox sensor LED
    digitalWrite(6, LOW);  //proximity sensor should start out off
void loop(){
     while(Serial.available())  //is there anything to read?
	char getData = Serial.read();  //if yes, read it
	if(getData == 'p')  //proximity sensor is giving reading
  	  digitalWrite(6, HIGH);  //turn on LED to show proximity warning
        Serial.print(getData);
//left switch was pressed; interrupt routine 0
void leftPress()
    //is the right blinker currently on?
    if(rightBlink)
      rightBlink = false;  //yes, so turn it off
      Serial.print('z');  //send reset signal to the rear microcontroller via xbee
      delay(50);  //delay for a bit to allow for serial buffer to clear
    leftBlink = !leftBlink;  //if left blink is on, turn it off, and vice versa
    if(leftBlink)  //is the left blinker currently on?
      Serial.print('l');  //yes, so send the data to the rear microcontroller
    else  //the left blinker is no longer on
    delay(1000);  //delar for a second to allow all buffers and serial data to send and be received from the rear
//right switch was pressed; interrupt routine 1
void rightPress()  //same as left blink, but opposite
    if(leftBlink)
      leftBlink = false;
      Serial.print('z');
      delay(50);
    rightBlink = !rightBlink;
    if(rightBlink)
      Serial.print('r');
      Serial.print('z');
//Interrupts code every second to pulse a low voltage to the 555 timer, casuing it to turn on the given blinker for 0.5 seconds
ISR(TIMER1_COMPA_vect)
    //should the left blinker be on?
    if(leftBlink)
      digitalWrite(4,LOW);  //yes, so pulse a low value to the left blinker 555 timer
    //the left blinker shouldn't be on, so should the right blinker be on?
    else if(rightBlink)
      digitalWrite(5,LOW); //yes, so pulse a low value to the right blinker 555 timer
Back:
#include <SPI.h>
#include <ADXL362.h>
#include <avr/io.h>
ADXL362 accel;  //accelerometer object
long Duration,inches;  //for PW prox info
const int slaveSelectPin = 10;  //accelerometer pin
int accel_old, accel_new;  //for accelerometer data comparison
int XValue, YValue, ZValue, Temperature;
  Serial.begin(9600);  //baud rate is 9600
  pinMode(2, OUTPUT);  //controls sleep mode of proximity sensor
  pinMode(3, OUTPUT);  //controls the brake ttl relay
  digitalWrite(3, LOW);  //brake lights should be off when loading
  pinMode(4, OUTPUT);  //555 timer for ttl relays, left blinker
  digitalWrite(4, HIGH);  //Keep high so blinker doesn't blink
  pinMode(5, OUTPUT);  //555 timer for ttl realys, right blinker
  digitalWrite(5, HIGH);  //Keep high so blinker doesn't blink
  pinMode(7, INPUT);  //reads PW info from proximity sensor
  accel_old, accel_new = 0;  //no acceleration data yet
  leftBlink, rightBlink = false;  //no blinkers should be on yet
  noInterrupts();
  //setup timer interrupt
  OCR1A = 15624;
  interrupts();
    //Setup accelerometer
    pinMode(slaveSelectPin, OUTPUT);
    SPI.begin();
    SPI.setDataMode(SPI_MODE0);	//CPHA = CPOL = 0    MODE = 0
    // Activity threshold
    digitalWrite(slaveSelectPin, LOW);
    SPI.transfer(0x0A);  //  write
    SPI.transfer(0x20);  //  Reg 20
    SPI.transfer(0xFA);  //  Reg 20 = dec 250
    SPI.transfer(0x00);  //  Reg 21 = 0x00
    digitalWrite(slaveSelectPin, HIGH);
    delay(100);
    // Inactivity threshold, and inactivity timer
    SPI.transfer(0x23);  //  Reg 23
    SPI.transfer(0x96);  //  Reg 23 = dec 150
    SPI.transfer(0x00);  //  Reg 24 = 0x00
    SPI.transfer(0x1E);  //  Reg 25 = dec 30
    delay(100);
    // motion detection, activity/inactivity detection
    SPI.transfer(0x27);  //  Reg 27
    SPI.transfer(0x3F);
    delay(100);
    // map awake bit to Int2
    SPI.transfer(0x2B);  //  Reg 2B
    SPI.transfer(0x49);
    delay(100);
    // begin measurement
    SPI.transfer(0x2D);  //  Reg 2D
    SPI.transfer(0x0A);  //  begin meanusre
    delay(100);
  delay(500);  //arbitrary delay to allow hardware to power up (probably not needed)
  char getData = ' ';  //character for serial data input
  if(Serial.available())  //is there something being sent to serial?
    getData = Serial.read();  //yes, so read it
  accel.readXYZTData(XValue, YValue, ZValue, Temperature);  //read the z-acceleration from the accelerometer
  accel_old = accel_new;
  accel_new = ZValue;
  int change = accel_old - accel_new ;
  if(abs(change) <= 5)  //is the bicycle stopped?
    digitalWrite(2,HIGH);  //no, so allow the prox sensor to read data
    delay(1);  //delay for a very short time so prox sensor can turn on
  Duration = pulseIn(7, HIGH);  //Read the duration of the pulse coming from the prox sensor in microseconds
  inches = Duration / 147;  //target is one inch farther away per 147 microseconds
  if(inches <= 48)  //is the target within 4 feet?
      Serial.print('p'); //yes, so send appropriate character wirelessly to the front
      delay(250);  //delay for a bit so the other microcontroller can recieve wireless signal and possibly send out it's own
  digitalWrite(2,LOW);  //turn off prox sensor until it is needed again
  //Rider is experiencing 50 mg's of force forward, meaning he is braking
  if(accel_new > 50)
    digitalWrite(3, HIGH);  //turn on brake lights when braking
    digitalWrite(3, LOW);  //turn off lights when not braking
  switch-case for input from serial. This takes care of all of the blinker systems.
  Character meanings:
  'l' means the left blinker switch was pushed
  'r' means the right blinker switch was pushed
  'z' means both blinkers should be off
  switch (getData) {
    case 'l':
      leftBlink = true;
    case 'r':
      rightBlink = true;
    case 'z':
    default:
//This interrupt routine will pulse the 555 timer to turn off and on the respective blinker every second
    if(leftBlink)
    if(rightBlink)
I'm not receiving on either XBee, but I can see the serial monitor printing out the right characters. Are there any settings I can change in X-CTU, such as the baud rate or the amount of packets re-sent, to overcome this problem? Or is this merely a code issue?
I do have the power connected to the 3.3V pin of the arduino, and I'm using 470/220 Ohm resistors as voltage dividers for the output pins from the arduino to the XBee, so I don't think voltage is an issue here.
Also, I have tried disconnecting the arduino from the computer. I powered it via the USB-A to USB-B cord -> 13000 mAh 5V DC rechargeable battery, so there should be no interference with the serial data lines. Pin 2 (RX) of the XBee is connected to pin D0 (RX) of the arduino, and pin 3 (TX) of the XBee is connected to pin D1 (TX) of the arduino. Still nothing.
Thanks for your help.
