A quick update. June 2015
I have a few hobby car builders and engineers interested in the project. It is a joint open/share project.
I have not given the data collection much thought beyond streaming to a PC. Ideally Excel or another capture program would be good.
Any suggestions welcome -
I have to send a command to operate the servo and capture a stream of data from 2 Bluetooth HC-05's in a 5 second period and dispaly the results and show a pass of fail icon.
The Problem
There are no after market seat meeting the current ADR Australian Design Rules. Our options are limited to seats (or head restraints) from production cars so let us test seats ourselves.
The ADR
From my research we need to test these specific items.
Head restraint deceleration.
Seat strength
Physical sizes
Head Restraint.
The speed of a 165mm diameter, 6.8kg Sphere at impact using the average of two accelerometers measuring deceleration.
Sphere speed at impact = 24.1km/h. Accuracy: + 2.5 % of the actual speed; Sensitivity: 0.5 km/h. Time recording – samples every 1msec.
Our rule of thumb is if the head restraint moves more than 30mm it should pass.
Seat strength
Mount seat vertically, load 20 times the seat weight, for more than 1 second, in all adjustable positions.
Physical sizes
ADR is clear but typically the seat needs to be around 900mm from the cushion to the top of the head restraint and openings and slots must not exceed 65mm (there are a few tricks to this)
Electronics –
Arduino Mega processor. It should be able to record the impact for about 3 to 5 seconds depending on how smart we can make the software.
Memory and data transmission rates are the bottlenecks.
Accelerometer – must read greater than 80g, more than 600Hz response.
Encoder to measure speed. Will require its own Arduino processor.
Bluetooth communications
SD (camera style) memory card
Servo release to initiate pendulum swing.
Hardware –
Sphere. I have a sphere to test with but I would love to get a local guy to manufacture these to ensure correct weight and ability to mount electronics.
Pendulum. A pendulum makes a lot of sense as the speed just prior to impact will not vary too much. The sphere suspended from an A frame, forklift or factory ceiling on some flat steel bar. A mechanism to capture the rebounding sphere?
The floor frame. Ideally a 50mm RHS with say a 6mm plate and tabs to bolt or secure to floor. We can secure chassis rails or seat runners to this frame.
