eu estou com meu arduino aqui e eu quebrei o pino do atmega que veio com ele e não tenho um cristal tem como fazer bootloader direto na placa?(sugestão para a arduino)
ou tem como usar o cristal oscilador e os capacitores do arduino?/
i have my arduino here and i broke the atmega pin that came with it and i don't have a crystal can i bootloader straight on the board? (suggestion for arduino)
Or can you use the oscillator crystal and arduino capacitors?
Hello WesiofilhoTI,
Welcome to the forum.
I noticed your question earlier and wondered if anyone would help, I see no one has. Some things that might improve your chances:
- First read 'how to use this forum - please read' (at the top of this and every forum) and follow the instructions.
- Second either post in English with an English title or post on the Portuguese forum with a Portuguese title.
- Third, the English version of your question does not make much sense, I suspect the Portuguese version doesn't either, you need to be a lot clearer about what you are asking.
Please can you address the above points and modify your post. If you want it in the Portuguese section click on 'report to moderator' and ask them to move it, don't post the same question in 2 different places as it just wastes time with people trying to answer in 2 different places.
Thank you
