Como fazer um retângulo piscar usando TFT com Adafruit, fiz um retângulo:
tft.fillRect(posx,posy, largura, altura, cor);
tft.drawRect(posx,posy, largura, altura,WHITE);
tft.setCursor(posx+8,posy+4);
Eu preciso que quando esse botão seja construído ele fique "piscando" para que ele seja meio que uma opção atual selecionada pelo usuário, e a medida que o usuário for apertar um botão outro retângulo comece a piscar, tentei fazê-lo piscar usando o while(1){} mas ele fica piscando o retângulo e não reproduz o restante do código (restante da tela).
I have TFT Display with AdaFruit library, i need to make my fill rectangle stay blinking while user don't press a physical button, in a LCD the function is "lcd.blink()", but, in TFT, i do not know if this exists.
You can make a blink yourself. Here is an example that runs on an ILI9481 3.5 inch TFT Uno shield. Youi can check with Serial Monitor.
// TFTT_blink.ino
// 3.5 inch TFT screen ILI 9481 320 x 480 pixels landscape
// 3.5 inch TFT Uno shield
// TFT control via pins A0-A4 and pins D2 thru D9
// uses mcufriend_kbv library
// this sketch paints your screen black
// displays a filled rectangle, color black
// waits 500 millis
// displays the same filled rectangle, color black
// waits 500 millis
// and on and on and on......
// by Floris Wouterlood - have fun
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define BLACK 0x0000
#define BLUE 0x001F
// TFT controller detection
uint16_t ID;
ID = tft.readID ();
Serial.begin (9600);
Serial.println ("starting TFT display");
Serial.print ("controller ID = 0x");
Serial.println (ID,HEX);
Serial.println ();
Serial.println ("drawing black square");
// static elements to be continuously displayed
tft.reset ();
tft.begin (ID);
tft.setRotation (0);
tft.fillScreen (BLACK);
tft.fillRect (50,50,100,100,BLACK);
Serial.println ("drawing blue square");
tft.fillRect (50,50,100,100,BLUE);
photoncatcher:
// TFTT_blink.ino
// waits 500 millis
// waits 500 millis
MCUFRIEND_kbv tft;
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define BLUE 0x001F
uint16_t ID;
ID = tft.readID ();
Serial.println ();
tft.reset ();
tft.begin (ID);
This solution is good, but only if we are not going to use physical buttons, otherwise the delay disrupts the buttons, but thanks, it worked
UKHeliBob:
Have you looked at Using millis() for timing. A beginners guide and Several things at the same time ?.
I do not know"Use millis() for timing", thanks for subject, i'll read now to learn.
