For an SD Card Audio Wave Player Design with push button to play assigned files from a folder present on the memory card I have this code below
if (digitalRead(2) == LOW)
tmrpcm.play("/1/001.wav");
if (digitalRead(3) == LOW)
tmrpcm.play("/1/002.wav");
if (digitalRead(4) == LOW)
tmrpcm.play("/1/003.wav");
if (digitalRead(5) == LOW)
tmrpcm.play("/1/004.wav");
if (digitalRead(6) == LOW)
tmrpcm.play("/1/005.wav");
if (digitalRead(7) == LOW)
tmrpcm.play("/1/006.wav");
if (digitalRead(8) == LOW)
tmrpcm.play("/1/007.wav");
Now how it is possible to make it a compact one as its a bit lengthy occupying space or memory !!
gfvalvo
October 31, 2022, 11:18am
2
Link the pin numbers and file names in a struct. Create an array of that struct for all combinations. Loop through the struct.
Ok
Actually sir I want to clear a base here
Would you please let me know a bit lil with a short script ?
gfvalvo
October 31, 2022, 11:33am
4
I don't know what that means.
Like how it works actually with array and loop
Which loop and how it determines
On net I am not able to find a perfect link to make it explain way better
Start by putting the pin numbers in an array with a sensible name (e.g. songSelectPins); you have examples in your other topics.
Next you can use a for-loop to iterate through the array and read the pins and if the pin reads LOW, build the filename.
If the relationship between the index in the array and the filename is linear (based on the example that you gave, it is), you can use sprintf or snprintf (C library function - sprintf() ; snprintf is a little safer) to build the filename and next pass it to tmrpcm.play() .
Ok for Sprintf I ll proceed later after the basic gets clear
I am still a bit confused with some areas
like
where to make arrays ?
I mean Within Setup or before that ??
Is it something like
char songList1[16];
songSelectPins[16] = (1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16)
sorry
its like
char songSelectPins[16] = (1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16);
Showing errors
'songSelectPins' does not name a type; did you mean 'SD_ChipSelectPin'?
Totally getting confused Sir please help to get me out of this
on basis of this
I made this one
float songSelectPins[16] = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16};
No errors for now
gfvalvo
October 31, 2022, 12:28pm
11
Crude, but it demonstrates the idea:
struct PinWaveStruct {
const uint8_t pin;
const char wav[16];
PinWaveStruct choices[] = {
{2, "/1/001.wav"},
{3, "/1/002.wav"},
{4, "/1/003.wav"},
{5, "/1/004.wav"},
{6, "/1/005.wav"},
{7, "/1/006.wav"},
{8, "/1/007.wav"}
for (auto &c : choices) {
pinMode(c.pin, INPUT_PULLUP);
if(digitalRead(c.pin ==LOW)) {
tmrpcm.play(c.wav);
guix
October 31, 2022, 1:33pm
12
Or maybe something like this
for ( uint8_t i = 2; i <= 8; ++i )
if ( digitalRead( i ) == LOW )
static char fileName[] = "/1/00X.wav";
fileName[5] = i - 1 + '0';
tmrpcm.play( fileName );
gfvalvo
October 31, 2022, 2:09pm
13
Personally, I think OP is fixating excessively on "compact" and "saving space" (goals whose details he's never explained and solving a problem he likely doesn't have). Given my perception of his coding abilities (based on questions and code posted), he'd be much better off writing code he understands and can maintain.
Don't use floats for pin numbers. There is no such thing as a pin with number 2.71 or a pin with number 3.14.
Post complete code using code tags and post complete error message, also in code tags. Do not post images of code !!
alto777:
2.72…
No, it's 2.71... or 2.72
But no wonder that I only barely passed my maths at university
Creating a very dangerous kind of noise for at least 2 seconds
Nothing happens other than this
Ya sure I am not applying float
That picture is an example from internet page & its not mine
Is this a joke of some sort?
guix
November 2, 2022, 1:26pm
20
No, why do you think this is a joke ?
